  New Posts New Posts RSS Feed: R-pod 179 newbies. Need help
Topic ClosedR-pod 179 newbies. Need help
Direct Link To This Post Topic: R-pod 179 newbies. Need help
    Posted: 21 Nov 2016 at 9:43pm
LOL
I've heard the guidance that if I am comfortable, my refrigerator will be also. I prefer to use a level and get it as close as I can. I also noticed that the floor of the R-Pod, the kitchen countertop,  and the refrigerator are not at the same angles. Using the refrigerator to level means the kitchen counter is not level. If I use the floor, the refrigerator is not level. I don't even think about using the countertop. The floor is at least close enough that the refrigerator has been operating without problems.
Direct Link To This Post Posted: 21 Nov 2016 at 7:30pm
I knew I was going to be "uncomfortable" when my dad gave me the 1st degree when I did something wrong.  So 3 degrees would be extremely uncomfortable!
CharlieM View Drop Down
Direct Link To This Post Posted: 21 Nov 2016 at 7:00pm
Originally posted by Happy Tripping
I believe that there is a bit of a controversy about this? I was told earlier on this forum that current reefers aren't as sensitive to level positions as earlier ones?
You are correct in that rumor has it the newer ones are less sensitive. However, I've never seen any new numbers published. Now the books say "if you're comfortable, your fridge is too." Not much for us tech types so I'll stick with the 3 and 6 degree numbers. That said, 3 degrees is quite noticeable if you're in the camper.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 21 Nov 2016 at 4:45pm
Originally posted by StephenH
The refrigerator must be near level ( 3 degrees side-to-side and 6 degrees front-to-back)  to operate properly. Operating while not level can damage it. See this video for more information:  Level your RV for proper operation of your refrigerator.
(I'd start another thread on this but I don't know how. This is an important question)
Jasp View Drop Down
Direct Link To This Post Posted: 21 Nov 2016 at 3:46pm
Thank you very much Charlie!!!
Direct Link To This Post Posted: 21 Nov 2016 at 2:57pm
Originally posted by Jasp
Does a bad level effect the refrigerator if it's not running ?? My winter storage is not even close to level.
Short answer is NO. Long answer is the same. Camp on! Smile
Jasp View Drop Down
Direct Link To This Post Posted: 21 Nov 2016 at 1:24pm
Carolavan View Drop Down
Direct Link To This Post Posted: 21 Nov 2016 at 8:16am
Thanks. I wondered what that thing was.
Direct Link To This Post Posted: 21 Nov 2016 at 8:15am
A muffin fan is a flat fan in a square frame. It is the same type seen in things like computers. Some run on 12V and some on 120V. The ones used for the refrigerator run on 12V. It is the fan you see when you take off the covers outside and look on the back of the refrigerator. It is mounted horizontally and blows air upward so that it will flow over the coil above it.
Direct Link To This Post Posted: 21 Nov 2016 at 6:47am
Thanks. Hopefully it is something simple. Pardon my ignorance, but what is a muffin fan?
