ouR escaPOD mods |
Page <1 4647484950 58> |
mountainman ![]() Newbie ![]() Joined: 24 Apr 2016 Online Status: Offline Posts: 24 |
![]() ![]() ![]() ![]() Posted: 04 Dec 2016 at 12:41pm |
StephenH, thanks for showing the block you made for jacking up the trailer. I will make one this winter. I can guess at the dimensions, but would it be possible for you to provide dimensions of it? Thanks.
mountainman |
The latest mod won't be new to anyone with a later model 2016 R-Pod, but it is new to me since I had an earlier 2016 179. Mine did not come with the flip foot or the undermount sink. I detailed my sink mod previously. Now I can detail the flip-foot mod.
Thanks to Mike who, when he changed his jack from manual to electric, found he could not really use the flip foot that came on his R-Pod. It did not work with the place in which he needed to park his 'Pod. The electric jack I installed a few months ago came with a round, adjustable foot. While it worked, it had its problems. For one thing, as the pod shifted with jacking, it could dig its edge into blacktop pavement. Second, one had to get down to remove the pin, adjust it, and put the pin back in. These are reasons for which I wanted a flip foot. The Husky foot I had purchased and tried was not quite what I wanted, so I appreciated the ability to purchase the flip foot and try it. My opinion is that I really like the flip foot. It sometimes needs a little nudge to get moving in the right way to set itself or to flip up, but that can be done without stooping over. Otherwise, the curved sides means it should not dig in to warm blacktop like the flat foot did. It seems to be perfectly adequate for supporting the tongue of the 179. I do not notice any instability when it is properly set. The retraction is nice too since I don't need to manually flip it up or detach it before traveling. ![]() The old foot is in the background, next to the red bottle jack. ![]() The acid test will be when we make our next big trip. |
The baking soda by itself followed by a flush with fresh water worked okay for me. I guess the water properties where one lives makes a difference also.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3324 |
My DW reminded me of the third ingredient to the above mix, white vinegar (and baking soda and concentrated lemon juice).
You're quite welcome. It is easy to overlook sanitizing the water system. Yet, sanitizing is the best way to ensure a safe water supply.
Yes, furpod gave me the 1st degree for not sanitizing my water tank . . . ever, since I purchased it March 2011. Late this spring I did use a weak solution of bleach and then used baking soda/concentrated lemon juice and let sit in tank overnight, took care of the bleach taste. Thanks for the post StephenH.
For those who choose to use RV antifreeze, the mod to access the valves will be useful. For those who choose to use just air,. it will not seem necessary. Air is easier, but I do recall reading some posts of those who used air who still had things freeze and break. RV antifreeze is more reliable, but has the downside of residual taste. After last winter, I sanitized the tank with chlorine bleach and then used a baking soda solution to help remove the odor and taste of chlorine. In the end, I don't recall any residual RV antifreeze taste, so I guess I did something right.
What is nice is that with such a small trailer and short runs from the blow out, the blow out procedure takes less than a minute. I have been doing this since 2012 and never knew about the low point drains until last winter, because they put a ton (not actually) of foam around them so I had to cut most of it away to actually find the drains, when I opened them after blowing out, maybe a couple drops came out of each.
Weekend Warrior ![]() Newbie ![]() ![]() Joined: 05 Nov 2016 Online Status: Offline Posts: 35 |
Cool, yep makes sense to blow out the lines than to mess with the traditional methods. There's a real neat rpod video on you tube that explains all the steps to totally ridding all the water out of the entire system by using compressed air but I can't recall the link off hand but it works great on these pods.
