  New Posts New Posts RSS Feed: Propane tanks
Topic ClosedPropane tanks
sailor323 View Drop Down
Direct Link To This Post Topic: Propane tanks
    Posted: 31 Oct 2016 at 11:57pm
I see no reason to disconnect the propane tank ever.  I do turn it off at the valve whenever we're not using it
Direct Link To This Post Posted: 31 Oct 2016 at 10:42pm
We have had 2 tanks on our 2011  177 since we picked it up in March 2011.  We are like furpod, they are always on until they run out.  As far as the cover goes, ours is hard sided and has seen 5 Michigan winters, still looks great, no cracking.
CharlieM View Drop Down
Direct Link To This Post Posted: 31 Oct 2016 at 10:17pm
If you have the soft Vinyl cover it will get brittle when cold and crack if handled. If you don't try to open it or look at the tanks when the cover is cold it will probably be OK. The hard sided cover should be OK in the cold.
Vector1952 View Drop Down
Direct Link To This Post Posted: 31 Oct 2016 at 9:15pm
Thank you, also will the plastic cover crack if left out or should I take it inside...
Xxxx7
Direct Link To This Post Posted: 31 Oct 2016 at 8:58pm
Other then when refilling or swapping out, mine are always mounted..
john in idaho View Drop Down
Direct Link To This Post Posted: 31 Oct 2016 at 8:15pm
I have left mine connected on various campers and trailers over the years without any problems.  Propane is one fuel that you can store almost indefinitely.  It also keeps insects and spider webs out of the connection
Direct Link To This Post Posted: 31 Oct 2016 at 8:02pm
Has anyone left their propane tanks connected in the winter, l live in new england
Xxxx7
