  New Posts New Posts RSS Feed: Fire Starting Kit:  the old way!
Topic ClosedFire Starting Kit: the old way!
ronahue View Drop Down
Direct Link To This Post Topic: Fire Starting Kit: the old way!
    Posted: 21 May 2017 at 9:54am
I start mine the old fashion way Duraflame, it has never let me down.LOL
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
flat6s View Drop Down
Direct Link To This Post Posted: 21 May 2017 at 9:39am
I was taught in survival training to use Frito Corn Chips.  Put some in a zip lock bag.  Does not matter if the get mashed or stay whole.  Use a pinch or more.  Good hot fire will erupt when touched by a match, or flint spark.  They are light.  Do not take up much room in your geat bag.  Cheap.  They work great.  Try one
VenturaTom View Drop Down
Direct Link To This Post Posted: 28 Nov 2009 at 10:44am
I'm with Terry....I like to use my small Weber grill...cook some dinner, then use the coals as a base for the fire.
Tom
R-Pod 177 with Chevy S-10ext Cab V6 puller
TerryM View Drop Down
Direct Link To This Post Posted: 27 Nov 2009 at 3:47am
Myself, i use self starting BBQ briquettes.  Put some down, touch them with a lit match and pile on the wood.  Works very well.  If I was a long distance hiker I would use it because of it being small and light weight BUT, I ain't so I won't!LOL
Terry
yizit View Drop Down
Direct Link To This Post Posted: 26 Nov 2009 at 11:47pm
Good information and something fun for kids to learn, as well as the big kids. But as for me...I'll stick to the Safe Lite Fire Starters   http://www.northlineexpress.com/category/fire-starters.aspThumbs Up
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Roada our 2004 Roadtrek C190Popular
Tusten Traveler View Drop Down
Direct Link To This Post Posted: 26 Nov 2009 at 11:05pm
Wow! John's an eagle scout so he will definitely be impressed.
As for me, I'll stick with:
 LOL
John and Linda
One 14 lb Cockapoo
2010 RPod 174
Direct Link To This Post Posted: 26 Nov 2009 at 3:52pm
Here is what Lewis and Clark did.  I'm not old enough to have gone with them, I was just a little tike, so I didn't see this in person!LOL
Get yourself a small metal box with a lid on it.  Something like an Altoids box.
1.  Cut pieces of an OLD 100% cotton "T" shirt that will just fit into the box.
2.  ****The next time you have a camp fire or BBQ going throw in the box.  When the fire has cooled down get the box out.  Inside you will have cotton charcoal.
3.  Get a small amount of tiny pieces of wood.  A good example would be the thin paper like wood found on the underside of some dried wood bark.  Add to this small twigs.  Very small.
4.  Here is the tough part.  Steel and flint.  What you need is high carbon steel.  I think steel files are but I'm not sure.  The flint ( also called Chirt ) can be had in most parts of the country just by looking on the ground for it.  Or you could go to a rock shop and get some.
5.  Put a sheet or 2 of the cotton charcoal on the ground, add a little of the thin wood, get close to your fire pit and strike the steel with the flint.  It would be a glancing blow going towards the fire material.  You should be able to get sparks this way.  The sparks are enough to set the cotton charcoal on fire which in turn would start the other wood.
**** The metal box you use should have a tight fitting lid.  Be sure to burn off all paint etc from the box before you first use it.  Add a tiny hole on each side of the box.  Whittle down a wooden match stick or other wood to tightly fit the holes.  When you are cooking the cloth watch the holes.  After gas comes out and burns there will be smoke.  As soon as the smoke stops get your can out of the fire and stick the hole plugs in right away.
See what is around your area that would be light weight and burn very easy to use as your first layer of wood on the charcoal.
You can put your charcoal, steel & flint and starting material all together in a nice little box and pack it away.  This does work.  I have done it.  I learned this at a Lewis and Clark Park.
Terry
PS:  If someone know what common things are high carbon steel it would help.
You can cheat and buy the charcoal cloth and flint here:  http://www.flint-rocks.com/?gclid=CKOng5fKqZ4CFRshnAodtR5umg
