Pmorris1
Topic: panel below gridge on 179 Posted: 09 Sep 2016 at 12:17pm |
Could you post a photo showing what you have done
TheBum
Posted: 09 Sep 2016 at 11:57am |
Originally posted by Pmorris1
I can't believe forest river couldn't come up with a better way to attach the panel. I'm surprised more owners haven't complained about this on here. I don't thing my wife would go along with the curtin, but thanks for the idea. I was thinking about a piano hinge. What problem did the hinge cause you? |
They work fine for items hitting the panel from the interior side, but if something gets in behind the panel, the hinges don't help when the slide is extended. The hinges are spring-loaded to keep the panel from "leaning back" into a non-vertical orientation, as it would do with piano hinges.
Since my prior post, I've figured out how to add a second set of hinges to allow the panel to swing out if something gets behind it when the slide is extended while still keeping the panel vertical when it's not under stress.
Pmorris1
Posted: 08 Sep 2016 at 8:46pm |
There are two screws , one on each end of the panel. The screws are screwed into a thin metal strip . The panel kind of just hangs, which allows the panel to move while your traveling . The movement causes the screws to loosen. Each time you relighted the screws the more they start to strip out in the original holes.i have went two sizes larger already, but after a while they won't hold the panel tight.
Mojave1
Posted: 08 Sep 2016 at 8:09pm |
I'm not familiar with how the panel fastens. However, might a BLIND NUT work?
Pmorris1
Posted: 08 Sep 2016 at 7:40pm |
I wonder if you ran a long piece of say 1" heavy strength Valcro all the way across the top of the panel. Put the other piece of Valcro across the opening below the fridge, and attached it that way. You could hang the panel once you put the slide out, and remove it when the slide is in while pulling the RV
Pmorris1
Posted: 08 Sep 2016 at 12:03pm |
MoPod
Posted: 08 Sep 2016 at 11:48am |
Originally posted by TheBum
I know some have replaced it with a curtain and I'm thinking more and more about doing that with ours. |
I like this idea. Since I was planning to redo the slide curtains in the back I'll have my sewing machine out and dusted off. Just need to buy more fabric.
Bill & Nancy
2015 RPod 179
Previously 2010 RPod 176
2014 Explorer Sport
TheBum
Posted: 08 Sep 2016 at 11:17am |
I added a hinge to ours to allow it to swing back, but even that has its issues if something gets behind it and you extend the slide without knowing it.
MoPod
Posted: 07 Sep 2016 at 7:08pm |
Following.....
Forgive me for stealing your thread, but I would also like to know if someone has removed the offending panel and replaced with something different. I'm tired of getting on my knees and poking wires back every time I open the slide to prevent stress on this panel.
Bill & Nancy
2015 RPod 179
2014 Explorer Sport
Pmorris1
Posted: 07 Sep 2016 at 5:28pm |
Has anyone had a problem with the panel below the fridge that hides many wires ,coming loose. there are only two screws that hold it at the top. this panel moves in and out as you open and close yout 179 slideout. I tried tightening the two wcrews every time,but they they keep coming loose while pulling your Ropd. finally my two screwa have stripped out and no lomger tighten. is there a way to correct this from happening.
