Page <12 |
bjk ![]() Groupie ![]() ![]() Joined: 23 May 2016 Location: Hillsboro, OR Online Status: Offline Posts: 65 |
![]() Posted: 13 Aug 2016 at 8:59pm |
In my most recent trip to North ID, I did hear my fans kick on. However, it was hot out and the fridge was facing west for the entire time I camped there. I even had my freezer insert in it and the fridge stayed reasonably cold. But I also learned long ago that the most optimal use of the fridge/freezer is a packed one. Harvested several Muscles and what I didn't eat I threw in the freezer and was amazed when I did get home, they were frozen solid.
2016 HRE R-179 "CapPODccino"
2011 F-150 SLX |
Thanks JandL for the link.
Have had our 177 since March 2011 and
have never heard those fans come on. Just did a test 20 minutes
ago to see if they actually work. Took off the 2 spade connectors connected to the thermal switch and ran a jumper to connect them together.
Found out they actually work, should have seen the dust blow off those
fans! Anyway, I figured the thermal switch must be junk so took that
off and tested that by holding a flame under it. In about 3 seconds I
heard a click so I immediately took my volt meter and tested for
continuity, which I had. About 25 seconds later it clicked off so it
must work, just odd that with the 'warm' weather we have had that it
doesn't activate. Appears that the current location is best for the switch.
osage ![]() Senior Member ![]() Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
just got back from Branson today while there the temps were in the 90's fridge ran 38 after I took the vent covers off. also I have moved the switch for the fans to the right just out side of the vents now the fans come on.
Thanks. I will probably go ahead and add at least one additional fan after we return from this trip.
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Here is a good post and pictures about the fans
fridge temp http://www.rpod-owners.com/forum_posts.asp?TID=8185 Edit: make link clickable - techntrek
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
Two muffin fans? We only have one on our 2016 R179. I also have seen less than adequate performance in hot weather, even after adding an inside circulating fan. My next step after we get home from this trip will be to try to hook up a couple of fans to help exhaust the hot air, which should help.
Just returned from Lake Huron where temps were in the 90's. Freezer compartment stayed cold but fridge was around 50 degrees with the setting at the lowest temp. Noticed that the 2 'muffin fans' located on the back of the fridge never came on. Is there a way to test these to see if they are any good or has anyone rewired them so they can be manually turned on and off with a switch? After taking both covers off, to get better air flow, the temp in the fridge did come down but would like to have these 2 fans come on to increase air flow. We have had our 177 for over 5 years and this has never been an issue since we normally don't camp during warmer temps as we had this past weekend.
Page <12 |
