Lighting furnace - Event Date: 25 Jun 2016 |
Page <12 |
densmorema ![]() Groupie ![]() ![]() Joined: 25 Jul 2016 Online Status: Offline Posts: 70 |
![]() ![]() ![]() ![]() Posted: 26 Jul 2016 at 10:59pm |
I n the fan mode on the thermostat
make sure its in the auto mode or the ac blower
will come on.
Mike and Cherie
Michigan 2015 R179 2016 silverado |
it should have auto ignition
just make sure the gas is on.
Mike and Cherie
ClariceRoberts ![]() Newbie ![]() Joined: 22 Feb 2017 Online Status: Offline Posts: 2 |
Yeah the thermostat should always be on the auto mode. A few days back, my aunt also faced the same situation. Her furnace was not lighting. Some one suggested to make sure the thermostat is on the correct setting and temperature, re-light the pilot if it has gone out, and make sure that the gas line is working. At last she decided to consult the professionals to make sure the problems are solved well. |
Clarice Roberts
traveleric ![]() Newbie ![]() ![]() Joined: 13 Sep 2021 Location: CO Online Status: Offline Posts: 4 |
Okay I have this exact same problem and the responses I’m seeing aren’t getting me to the fix. Would love how to get my furnace to kick on.
2017 rpod 178 Also I’d anyone had the furnace manual link handy? Thank you kindly. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6427 |
Ensure there is propane in the tank, the tank is connected to the regulator, and the valve is turned on. Check by lighting the stove to verify that propane is flowing properly. Potential problems: No 12V power. Make sure the battery is correctly connected and that you have power to the system. Blown fuse for the furnace. If fan is not even running, then this might be the problem. Bad or stuck sail switch (lets the furnace electronics know that the blower is moving air properly). If the fan is running but gas does not flow, this could be the cause. Bad electronics for the furnace. This has been known to happen. |
I think the issue is a bad sail switch. Will replace this weekend and let you all know.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Online Posts: 3345 |
Have never had this happen (yet) but expect it could be an issue to pop up on our 11 year old 177. Please let me know how involved it is to change the sail switch and how long it took to do the job. Thanks. We have used our furnace a lot over the last 11 years as we do the bulk of our camping in spring or fall when there are less people camping as versus the summer time.
Page <12 |
