  New Posts New Posts RSS Feed: WASPS
Topic ClosedWASPS
hogone View Drop Down
Direct Link To This Post Topic: WASPS
    Posted: 26 Jun 2016 at 9:35am
have some wasps building a nest in heater vent (in one of the two vents outside if that makes sense!!)  how in the heck am i gonna get that out of there without getting zapped??!!  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 26 Jun 2016 at 10:03am
You could try taking a shop vac and getting them out that way. However, then you would have a shop vac with some very upset wasps.Shocked Or, you could turn the furnace on and roast them if they have not yet built a nest large enough to block the airflow. Stern Smile
This might be better: In the evening, when they settle down, spritz some wasp killer in there? Once they are dead, then you can get the nest out. Afterward, put screens over the openings. I ordered screens from Amazon for all the openings in the furnace, water heater, and refrigerator.
Pod People View Drop Down
Direct Link To This Post Posted: 26 Jun 2016 at 10:34am
I made screen coverings for all of the vents. I used standard aluminum screen wire and a hot glue gun.  the screen wire is small enough gauge that it can easily be bent and cut with kitchen scissors.  I formed the screen in the size and shape necessary and then used the hot glue to attach it to the vent covers.  I did this several years ago and they are still totally stuck tothe covers.
Vann
Vann & Laura 2015 RPod 179
john in idaho View Drop Down
Direct Link To This Post Posted: 26 Jun 2016 at 11:27am
Shoot some wasp and hornet spray in each hole - doesn't take much.  Walk away and check in a few hours. If no activity, take the cover off and flip the nest away.  Don't worry about the wasps that didn't get zapped - they will die anyway since they don't have a home.  The fumes shouldn't get into the coach, since the burner is completely outside.
Direct Link To This Post Posted: 26 Jun 2016 at 11:44am
ya i shot a little juice in there!!!!!!!  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 26 Jun 2016 at 12:18pm
I assume a flame thrower is out of the questionYing Yang
