  New Posts New Posts RSS Feed: Power consumption of appliances
Topic ClosedPower consumption of appliances
WillThrill View Drop Down
Direct Link To This Post Topic: Power consumption of appliances
    Posted: 22 Jun 2016 at 11:13pm
Originally posted by Kantuckid
The previous owners of our Model 177/2016 said the jensen entertainment center will drain your battery when trailers sitting idle. I have a battery disconnect that takes care of that issue but would be even better were there a way to easily kill it dead when campers not being used.
Truth be told, you shouldn't be leaving your Pod's battery just sitting out anyway, regardless of whether it's connected or not.  Lead acid batteries self-discharge, and they should be kept on a quality smart charger 24/7 when not in use on the Pod or else left connected and your Pod left plugged in to a power source when not in use.  This will greatly lengthen the lifespan of your battery.
2014 Hood River 177
2005 GMC Envoy XL
Kantuckid View Drop Down
Direct Link To This Post Posted: 22 Jun 2016 at 9:50am
Pod People View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 5:06pm
THANKS to both of you. that is very helpful.
Vann
Vann & Laura 2015 RPod 179
JandL View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 12:20pm
This is the measurements I have made on my trailer. Your results may vary do to different manufactures. My microwave/oven is from Sunbeam and the television is a NAXA
AC & Fan start/run 23/16 amps
AC Fan only Hi 3.5 amps
Microwave 18/9.5 amps
Grill 8.75 amps
Convection oven 13 amps
Water Heater 11 amps
Refrigerator 1.2 amps
Battery Charger (max) 7.9 amps
TV 1.8 amps
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
pnwcamper View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 10:36am
Here you go
http://www.rpod-owners.com/forum_posts.asp?TID=1723&PID=14737&title=creating-an-instruction-maintanence-manual#14737
2014 R-Pod 177
2009 Toyota Tacoma Access Cab 4.0 V6
Direct Link To This Post Posted: 20 Jun 2016 at 9:05pm
I have seen and used a chart that some one made that showed the power consumption of the refrigerator, heater, fan,  etc for the RPod. I have searched and can't find it. Can someone please point me in the right direction
Thank you
Vann
Direct Link To This Post Posted: 20 Jun 2016 at 9:03pm
