  New Posts New Posts RSS Feed: walk through space with slide retracted
Topic Closedwalk through space with slide retracted
Westgl View Drop Down
Direct Link To This Post Topic: walk through space with slide retracted
    Posted: 14 Jun 2016 at 2:46pm
Picking Up 179 Monday,
I was wondering what the walk through spacing is when slide is retracted, since some quick overnight late possible wally world or fred meyer stops may happen, in route to destinations, and want to be able to get to the other parts of the Pod,  like the facilities with slide retracted.
2010 RAV4 V6
2017 RPOD 179 Hood River Edition
Dual 6 volt Batts
Dual propane Tanks
Batt Disconnect
Bed leg extension
Dinette modification
Renogy 100w solar
Motorcycles several currently
Jewel59 View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 2:56pm
I have a 180 and yes you can move around, not much but you can.
Direct Link To This Post Posted: 14 Jun 2016 at 3:40pm
It will depend on how you plan on carrying your table. If you strap in on top of the couch like some folks do,  you will have plenty of room to walk by and you will be able to open the bathroom door. If you strap the table next to the couch, you will not.
TheBum View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 3:58pm
What Leo said.
I've used our bathroom in a similar situation a few times.
ronahue View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 4:12pm
We often stop to picnic while traveling with our 179 and without opening the slide you have access to everything except the cabinet door to the right of the sink as you face the sink.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
Direct Link To This Post Posted: 14 Jun 2016 at 7:32pm
Thank you everyone for your quick replys
2010 RAV4 V6
Dual 6 volt Batts
Dual propane Tanks
Batt Disconnect
Bed leg extension
Renogy 100w solar
Direct Link To This Post Posted: 15 Jun 2016 at 9:09am
Congratulations on your 179!
I concur. We keep our table strapped inverted on top of the cushion with the tie-down strap over the bar. That way, we can easily get through and open the door to the bathroom. The dinette ends on either side of the table provide a place to sit if we want to stop for lunch but don't want to set up the table. As was stated above, the only things not accessible with the slide retracted are the cabinet to the right of the sink and the storage area under the cushion next to the bed. I added storage space to the end next to the refrigerator (see my mods). That is also not accessible with the slide retracted. The two dinette ends could be if I were to add a door on the side or end of each of them instead of just having access through the top.
