Page <123> |
fredtello1 ![]() Newbie ![]() Joined: 15 May 2016 Online Status: Offline Posts: 9 |
![]() Posted: 20 May 2016 at 2:28am |
to hook up.... buy a pvc pipe to fit over the crank.... glue an elbow on it and then glue another pipe at length to just touch the middle of your back window.... it will help you line up.. they sell metal ones that stay on the hitch with magnets....... google hitch alignments..... https://www.bing.com/search?q=hitch%20alinements&pc=cosp&ptag=C1AE89FD93123&form=CONBDF&conlogo=CT3210127
Rustler ![]() Senior Member ![]() ![]() Joined: 07 May 2016 Location: S. Oregon Coast Online Status: Offline Posts: 100 |
Thanks for asking the questions about single person setup. My wife and I just bought a Rpod 171. But my first trip will be solo, going to the Golden State Star Party by myself. So the answers to your questions have been most useful. Later my wife will be with me for other camping trips this summer. I hope you and your four-legged companions enjoy the trips.
Russ
2009 Toyota RAV4 V6 w/ tow package 2016 Rpod 171 HRE |
+1 I do this most anytime that I don't need to use the truck to run around and the campsite is close to level. It sounds like you'll have a nice setup. I'll add, if you are not familiar with backing a trailer, you might want to find an empty parking lot to practice backing up. Again, this is something that gets easier with time/practice. |
Jewel59 ![]() Groupie ![]() Joined: 19 May 2016 Online Status: Offline Posts: 70 |
I was wondering if this would be ok...leaving it hitched? Can you still hook to water and electricity safely? the type of sites at shows are very level. I'm super excited. I pick it up on Monday. I was supposed to get it yesterday but we had horrible rain in the area and I didn't want to start my first time on the road with it in horrible weather. Had a huge box from Camping World arrive and another from Amazon. I think I have all the necessities (leveling blocks, chocks, stabilizer pads and all the stuff for the inside to make it functional).
It's fine to connect water and shore power while connected to the BMW. I would add only one caution. Tow vehicles are generally wired to charge the trailer battery while traveling, but electrically disconnect when the engine is off. I say generally, but stuff happens and mistakes are made. The consequences are possible discharge of the BMW battery if shore power is not used. This can really ruin your morning. It's worth checking out. There are ways to check using a voltmeter, and even a way to check without a meter if you don't mind disconnecting the trailer battery. Let me know and I can talk you through it. Have fun and enjoy your camper and dogs
pnwcamper ![]() Newbie ![]() ![]() Joined: 22 Sep 2015 Location: Oregon Online Status: Offline Posts: 38 |
I have a back up camera which makes it much easier. With a little practice you wont have any problem, just go slow and easy when backing up. Unhooking is easy.
2014 R-Pod 177
2009 Toyota Tacoma Access Cab 4.0 V6 |
David D ![]() Newbie ![]() Joined: 27 Apr 2015 Location: San Jose, CA Online Status: Offline Posts: 26 |
As was mentioned earlier, backing up might be the toughest when on your own. In cases like this, I've adopted a method which is tedious but works.... back up the trailer a few feet, get out of truck walk to back to study progress, get back in truck, and repeat process over and over until your good. I actually learned this the hard way.... backed up into a tree once... embarassing! ;-) And, if you have to unhitch and still need to move your trailer, another item which has been super helpful is the Trailer Valet. I absolutely love this product. https://www.trailervalet.com/5x
2015 R-Pod 179
Capt Kidd ![]() podders Helping podders - pHp ![]() Joined: 18 Aug 2015 Location: Chico, CA Online Status: Offline Posts: 215 |
You might want to consider getting an electric jack in place of the hand one on the trailer. As I get older I find this to be a nice, not too costly, up grade. Makes it much easier to get on and off the ball.
The Pirate's Pod
TheLoneRanger ![]() Newbie ![]() ![]() Joined: 21 Jun 2016 Location: Utah Online Status: Offline Posts: 13 |
To help line up the trailer to the tow vehicle I purchased this $10.00 solution from Harbor Freight.
![]() http://www.harborfreight.com/catalogsearch/result?q=trailer+alignment The 1st time I tried it I still had to get out and check it was aligned a couple of times. However, I am sure after some practice I will be able to get it aligned correctly the 1st time. |
ChetC ![]() Groupie ![]() ![]() Joined: 17 Jul 2016 Location: Las Vegas, NV Online Status: Offline Posts: 43 |
As someone who hitches and unhitches a lot, I have one helpful tidbit of advice. Go to your local hardware store and purchase a cordless "driver" gun. Looks just like a cordless drill, but if designed to drive screws, bolts, etc... With that, get a socket adapter (it may come with one) and a 19mm socket to fit. Use this driver to run your stabilizer jacks up and down. Much faster and easier.
The only time I don't use the driver for the jacks is if I arrive at a campground late or leave early. They are a touch loud and I don't like to disturb my neighbors.
Former 2017 rPod 180 owner
Now in a 2019 Little Guy MAX Full timer who logs more than 35,000 miles per year. |
Page <123> |
