Page 12> |
Author | |||
![]() Posted: 05 May 2016 at 10:38am |
For the effort and expense, you ought to at least look at new cables. As David said too, you're just creating another potential failure point and one that may be the last one you look at if you ever have to troubleshoot.
TT |
FJ Cruiser |
A Bic lighter will work. Just be careful not to get the flame too close to the heat shrink tubing. |
johnmaci ![]() Senior Member ![]() ![]() Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
I agree, but my limiting factor is that I am using an outdoor storage facility and have no access to 120v to run an iron or heat gun :(
I am not a big fan of butt splices on anything mobile. I recommend a soldered sleeve with heat shrink insulation if you must extend a wire. |
Thank you!!!!
sailor323 ![]() Senior Member ![]() Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Use the same gauge wire and butt splice with heat shrink butt connectors
An easy fix would be to go to your favorite home store (like Lowe's, Home Depot) and pick up the needed lengths of wire and some ring terminals (crimp or solder)and replace the existing. While you could splice them, it adds "points of failure/problem" and, if nothing else, looks amateurish. The positive should go to a circuit breaker near the batteries. The negative - just trace it back on your particular camper. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Okay. That explains why. I hope you find a solution that won't cost much.
Thanks. I ended up getting a taller box, and now the cables don't reach.
You would want to use at least the same gauge of wire to extend the wires. It seems strange that just replacing the battery box would leave the cables too short. Did you move the batteries in the process?
In any case, head to your local auto parts shop. Someone there should be able to advise you on the best way to extend your cables. |
Page 12> |
