  New Posts New Posts RSS Feed: Sam's Club Mattress
Topic ClosedSam's Club Mattress
Direct Link To This Post Topic: Sam's Club Mattress
    Posted: 20 Apr 2016 at 12:33pm
The original mattress is right on the wood. While you have the old mattress out, you could do something like seal the wood with a polyurethane finish and/or cover the wood with some sort of contact adhesive plastic, but what you do is your option.
Have you gotten up the nerve to install the door window yet?
hogone View Drop Down
Direct Link To This Post Posted: 20 Apr 2016 at 6:19am
mattress arrives today!!!  curious, does anyone put anything down first/under the mattress; or lay it right on the wood?  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 16 Apr 2016 at 9:34pm
So was I. I did it anyway. You can do it too.
Take the door off and support it on a couple of sawhorses. That will help greatly. To remove, take the door off the hinges, leaving the hinges and screen attached. Be careful and place some protective padding on the wheel well or you will end up scratching it like I did. Unhappy At least I could get a little paint and touch it up. You get to benefit from my mistake, as you will be able to avoid doing likewise. Get some help when you remove and reinstall it.
When you put the window in, have the outside of the door facing down. Support the door and window from underneath. That will help when you go to start the screws. I found that a power drill/driver worked best for starting and driving the screws. When the thread catches, it will draw the two parts together and compress the rubber seal. That will make it watertight. The hardest paret for me was getting the screws started. I am just glad that lots of extras were included. Big smile
Direct Link To This Post Posted: 16 Apr 2016 at 8:06pm
Take a deep breath and go for itApprove
Direct Link To This Post Posted: 16 Apr 2016 at 6:48pm
stephenh;   im scared!!!  seriously.  hogoneGeek
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 16 Apr 2016 at 2:41pm
Measure twice (or three times), cut once. Use the trim ring to verify placement and size of the opening before you cut. You can make a cardboard template (which is what I did) and use that to help with placement and marking of the opening location. Cover the door with masking tape and mark on that and cut with it in place to protect the door. I cut from the inside. Drill a starting hole inside the marking for the opening and use a fine-toothed blade in your jigsaw. Go slow so you cut smoothly. Use a thin and not a wide blade so you can pivot at the corners easier.
If anything, cut the opening a bit smaller and enlarge it carefully as you go. You definitely don't want to cut it big. It is easy to cut a bit more out. You can't easily put material back if you cut it too big.
Direct Link To This Post Posted: 12 Apr 2016 at 6:30am
no, i meant me cutting the hole in the door for the window!!  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 11 Apr 2016 at 8:02pm
If you want to be safe, just cut it open outside of the pod and let er rip!  You will need a helper to get the mattress situated in the pod however.
Direct Link To This Post Posted: 11 Apr 2016 at 7:52pm
clear.  thats what i thought!  hopefully comfy.  scared about cutting door though but i guess at worst i just have a plywood doorWink.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 11 Apr 2016 at 7:47pm
Jon, if that is anything like the one we got from Camping World - mattress rolled up like a jelly roll.  Stand back when you cut the plastic liner, it will explode in front of your eyes and lay flat on your luan platform where the bed mattress is supposed to be.  Pretty neat.
