mesamie
Topic: GFI house breaker Posted: 29 Mar 2016 at 10:17am |
After de-winterizing, and reconnecting the battery, when plugged into the house power, the POD trips the GFI breaker. It did not do this last year. NOTHING is even on in the R-pod. We took it camping and on power at the state park, all was well. Could I have connected the battery incorrectly, ie. ground wire, or do I have an adapter problem....or something more serious ?
Posted: 29 Mar 2016 at 10:23am |
If it doesn't have an issue elsewhere, then the issue is probably with the house GFCI. They do malfunction/get weak.
The battery is on the 12v side and other then being charged by the converter, has nothing to do with AC side.
Retroactive
Posted: 29 Mar 2016 at 10:36am |
As Furpod said the GFCI have a limited lifespan, I have run into some weird cases. In my master bath I had one that only had and electric toothbrush plugged in, and if I plugged in a 3w nightlight in it the GFCI tripped (whaaa???). If you are handy with house electrical, I would replace that before troubleshooting the Rpod (takes 15 minutes and costs ~$10). Then you can also upgrade to a 20amp GFCI, you might have a 15amp at your house - since that is the cheaper "contractor grade" used in most construction.
mesamie
Posted: 29 Mar 2016 at 10:38am |
can I purchase these at Lowes ?
Retroactive
Posted: 29 Mar 2016 at 10:41am |
Yes. Any hardware store should have them. Just make sure to find at least a 20amp rated one, since that is what the RV shore power adapter is rated for.
mesamie
Posted: 29 Mar 2016 at 10:44am |
wonderful. I don't think it will reach, but should I try a different house outlet to see if it pops that ?
Retroactive
Posted: 29 Mar 2016 at 10:47am |
Only if the different outlet is a GFCI too. Otherwise you will not have an "apples to apples comparison".
mesamie
Posted: 29 Mar 2016 at 10:48am |
thanks so much, off to the hardware store...wish me luck !!
JandL
Posted: 29 Mar 2016 at 10:55am |
If you replace the GFCI make sure it's a Spec or Contractor grade and Weather Resistant. My personal preference is to try find one that does not have the Tamper Resistant option. Most outlets come with the Tamper Resistant due to changes in the NEC.
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
How are you plugging in? are you using just the adapter puck on the 30A shore power cord, or are you using a standard extension cord also?
