  New Posts New Posts RSS Feed: CAULKING
Topic ClosedCAULKING
Direct Link To This Post Topic: CAULKING
    Posted: 04 Apr 2016 at 12:00pm
Originally posted by GLBCamper
Originally posted by David
UPDATE...It looks like it they have changed the name (says original formula)
Polyseamseal
Which exact product do you use on exterior windows? The link goes to all of loctite sealants.
Good question! The last time that I bought some, it was still labeled "Polyseamseal" All Purpose. If I were buying today, I would likely purchase the "Premium". I use it on window frame to gel coat. I also use it around the side marker lights, porch light, etc. I don't have anything negative to say about the stuff. It seems to have good adhesion, resists mildew, remains somewhat flexible and is easy to work with. Clean up with soap & water.
In theory, there is a rubber gasket sealing the window frame to gel coat mating surfaces. However, I like to take the "belt and suspenders" approach and keep a thin bead of caulk around them.
GLBCamper View Drop Down
Direct Link To This Post Posted: 04 Apr 2016 at 1:00am
Polyseamseal
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
JandL View Drop Down
Direct Link To This Post Posted: 27 Mar 2016 at 6:48pm
I would not recommend using a silicone. When I have used silicone where I use to work you have to do a lot of surface preparation and priming to make it work correctly. When I did marine electronics repair I stayed away from silicone because most of manufactures say not to be used below the water line of your boat and it can also corrode electrical connections if you use the wrong one. I inspect every seam once a year and touch up where I think it needs it. I have tried different sealants and right now my favorites are Dicor Lap Sealant Self Leveling #501LSW and the Non-Leveling Non-Sag #551LSW. A couple of months ago I replaced my TV antenna with a new one I used the Self leveling sealant for the first time and I was very impressed with how well it leveled out. I am not sure what type of sealant the Dicor Lap Sealant is. I looked at their MSDS and think it might be a Butyl, solvent based sealant. There are 7 types of sealant Latex, Acrylic, Butyl, Polysulfide, Silicone, Polyurethane and MS Polymers (Modified Silicon).
Here is a very good article from Good Old Boat about the 3 different types of sealants, Silicone, Polysulfides, Polyurethanes
Suffering from sealant confusion? (marine)
http://www.goodoldboat.com/reader_services/articles/sealant.php
How to Choose a Sealant That Works (Buildings)
http://www2.buildinggreen.com/blogs/how-choose-sealant-works
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
hogone View Drop Down
Direct Link To This Post Posted: 27 Mar 2016 at 4:13pm
cool.  happy bunny hunting.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 27 Mar 2016 at 12:41pm
Polyseamseal
Direct Link To This Post Posted: 27 Mar 2016 at 12:21pm
Originally posted by Leo B
I inspect our each season and only re-caulk if it needs it or if a leak springs up
X2 / Leo B.
I use a product called "Polyseamseal" (made by Loctite, I think)and have been pleased. It can be had at home centers, hardware, paint stores, etc. Clean and prep is key to long term success.
It is not often that I have to do much of anything.
Direct Link To This Post Posted: 27 Mar 2016 at 11:46am
So far, the only spot that has needed recaulking was over the back window. Just cleaned the old off, put down new. I have redone the Lap sealant at the top of the spoiler, and around one of the sewer vents.
john in idaho View Drop Down
Direct Link To This Post Posted: 27 Mar 2016 at 11:24am
If you recall, what do you use?  I have found that silicone doesn't last long, and can be hard to remove.
Direct Link To This Post Posted: 27 Mar 2016 at 10:10am
Podster View Drop Down
Direct Link To This Post Posted: 27 Mar 2016 at 9:09am
The only entity that I have ever heard speak of such things is a dealer that wanted to charge a nice lady $1,200 to remove and replace all of the caulking on her POD.
Cliff & Raelynn
Ranger 4.0/178
