Page 12> |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1060 |
![]() Posted: 27 Mar 2016 at 8:19am |
the overall condition of my pod is very good. did a pretty thorough inspection of the exterior caulking yesterday which also seems quite good. for preventive sake, would one want to redo it; some/all? it looks fine. just a curious hogone question. hogone
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
The only entity that I have ever heard speak of such things is a dealer that wanted to charge a nice lady $1,200 to remove and replace all of the caulking on her POD.
Cliff & Raelynn
I inspect our each season and only re-caulk if it needs it or if a leak springs up
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
If you recall, what do you use? I have found that silicone doesn't last long, and can be hard to remove.
So far, the only spot that has needed recaulking was over the back window. Just cleaned the old off, put down new. I have redone the Lap sealant at the top of the spoiler, and around one of the sewer vents.
X2 / Leo B. I use a product called "Polyseamseal" (made by Loctite, I think)and have been pleased. It can be had at home centers, hardware, paint stores, etc. Clean and prep is key to long term success. It is not often that I have to do much of anything. |
cool. happy bunny hunting. hogone
Jon & Pam
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
I would not recommend using a silicone. When I have used silicone where I use to work you have to do a lot of surface preparation and priming to make it work correctly. When I did marine electronics repair I stayed away from silicone because most of manufactures say not to be used below the water line of your boat and it can also corrode electrical connections if you use the wrong one. I inspect every seam once a year and touch up where I think it needs it. I have tried different sealants and right now my favorites are Dicor Lap Sealant Self Leveling #501LSW and the Non-Leveling Non-Sag #551LSW. A couple of months ago I replaced my TV antenna with a new one I used the Self leveling sealant for the first time and I was very impressed with how well it leveled out. I am not sure what type of sealant the Dicor Lap Sealant is. I looked at their MSDS and think it might be a Butyl, solvent based sealant. There are 7 types of sealant Latex, Acrylic, Butyl, Polysulfide, Silicone, Polyurethane and MS Polymers (Modified Silicon).
Here is a very good article from Good Old Boat about the 3 different types of sealants, Silicone, Polysulfides, Polyurethanes Suffering from sealant confusion? (marine) http://www.goodoldboat.com/reader_services/articles/sealant.php How to Choose a Sealant That Works (Buildings) http://www2.buildinggreen.com/blogs/how-choose-sealant-works |
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
GLBCamper ![]() Senior Member ![]() ![]() Joined: 30 Jun 2015 Location: Oregon Online Status: Offline Posts: 274 |
Which exact product do you use on exterior windows? The link goes to all of loctite sealants.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab New: 2016 EVO ATS 200rd 2016 F150 4x4 Sport |
Page 12> |
