Page <1234 5> |
Author | ||
JohnBG ![]() Senior Member ![]() Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
![]() Posted: 24 Mar 2016 at 5:08pm |
I just put the wasp vents on mine last week for the fridge vents, heater vents and water heater door. Mud daubers here in FL are brutal.
Camco model numbers: Fridge vents - 42154 - you need 2 packs of these Heater - 42141 Water Heater door - Need 42145 and 42150 Available at Amazon.
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
You probably know that they make screens for the openings to keep these critters out and some use them. My only concern is that I would forget to clean the screens and the units would malfunction due to a lack of air supply.
It's hell getting old but, fortunately, I don't remember most of the troubles that I have. ![]() |
Retroactive ![]() Senior Member ![]() ![]() Joined: 15 Mar 2016 Location: Bolton, MA Online Status: Offline Posts: 270 |
Oh yes, we get all sort of nasty wasps and stuff that love to crawl into everything. They have a way of always showing up somewhere new.
Your fridge should have a vent system for propane. I posted some pictures of mine a while back. fidge/vent pics The rooftop vent cover is long and low (compared to the AC shroud). The flue assembly can get quite warm when operating so, be careful when touching. I like to periodically check this compartment for wasp nests, mud daubers, etc. Sometimes, they get in there and cause problems. |
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
I always have the windows open a crack (not near the bed) when it's cold out and I have to run the MrBuddy. No worries about condensation or CO asphyxiation. When it's cold (<40°F), the humidity levels outside are very low anyway. Most condensation will come from breathing.
Before I got the MrBuddy heater, I learned about condensation on my first cold night camping. A LOT of water on the rear window over the bed, and the mattress was wet on the edge too. I read up on the internet and learned I had to keep the windows cracked to prevent it. So now I slightly open the bathroom fan vent, and a windows near the front of the Pod. Plenty of covers, Merino wool socks, and a light Merino wool cap. Perfect.
The fridge always uses a little 12 VDC battery power when running on propane only. It is for the electronic circuitry in the fridge/panel. Even though the fridge can run a LONG time on a 20 pounds of propane, the battery might be dead by then.
I don't know if anyone has tested the longevity of the battery for running the fridge on only propane. It would be interesting to see which gave out first, the propane or the battery.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
The 12v mode is absorption also, same as the 110v mode. All three operate on the principle of heat to evaporate the ammonia which then is condensed and then evaporates again when it hits the hydrogen gas in the freezer section and refrigerator section. There is no TEC or compressor. We found out that dual 6V batteries will be drained down overnight. It was not enough to kill them entirely, but enough so that the refrigerator started beeping. This was after about 5-6 hours. Running on propane, however, worked very well, and saved the batteries for more important use, such as running my CPAP machine. |
Patriot Dave ![]() Senior Member ![]() ![]() Joined: 06 Feb 2016 Location: LaSalle, Mi. 48 Online Status: Offline Posts: 206 |
Having come from Hospital Facilities Engineering, I can tell you I have seen Absorbers (what we called them) up to 1000 tons of AC, powered by steam generated by boilers.
They do have a few issues that come with them. They tend to need a bit more maintenance and hands-on operating. If you have the extra steam capacity, good natural gas rates, and high electrical rates you can usually show a significant savings running them. |
Dave & Joyce
Never Forget, In God We Trust; This Our National Motto. Member; Patriot Guard Riders, Michigan Chapter Retired; So Every Day is Saturday.... Except Sunday |
As long as you can keep the 12v system topped off, or are very miserly with it, your limiting factors off grid are water, (and holding tank size), then propane. You give up a/c and microwave. But the pod is usable minus those two things, for as long as you can keep up with the other 2..
Absorption fridges can and will work on any heat source. Amish here run them on diesel.. |
It's really interesting that they can get the chemical reaction to keep regenerating, on a flame that is apparently about the size of a pilot light. I knew they had full size units for people in remote areas, I just had no idea they could pull it off on such a small scale and without dedicated venting - but the heat and CO it gives off must be negatable. Does the 12v mode run the compressor, or does it have a TEC unit in it?
Page <1234 5> |
