hogone
Topic: new tv/dvd Posted: 21 Mar 2016 at 7:31pm |
ok hang in with me(hog two can canoe a mean stream but pretty stupid on this!!!). just took my tv down ( the audivox combo) from the head banger. just kind of looking in the hole where the wires/cords go through (and electrical is back there too). the are two cables i pulled out, one says to tv2 and one says to tv3. obviously not needed for my hookup, but what are they for? or are they spy cables!! hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted: 21 Mar 2016 at 7:44pm |
Did you disconnect these 2 cables from the back of the antenna/satellite/cable outlet thingy? There should be no "extra" coax up there.
hogone
Posted: 21 Mar 2016 at 8:22pm |
no, only disconnected the cable from the tv/dvd to the antenna hookup(thats all there was hooked up)and electric. and yes the booster must be hooked up as it functions differently when the booster was pushed vs not), 1 cable wire and the juice that's all that was connected to the system. just happened to look back there, felt some extra cable wires, gently pulled out, and they have tags on them indicating what i mentioned. probably no biggy, am just curious. might put bose in!! hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted: 21 Mar 2016 at 10:28pm |
then the two you found should be the cable and satelitte feeds from the side of the Pod..
hogone
Posted: 22 Mar 2016 at 7:25am |
ok so i guess what im hearing is the cable for satellite is likely not hooked up to the back of the box inside the headbanger(the box that also has the antenna hookup) correct? have never used the cable/satellite hookup and probably will not, so no biggy. hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
