  New Posts New Posts RSS Feed: New owner
Topic ClosedNew owner
CozyPod View Drop Down
Direct Link To This Post Topic: New owner
    Posted: 25 Feb 2016 at 3:47pm
Welcome and congratulations!!
David & Suzanne
Direct Link To This Post Posted: 25 Feb 2016 at 12:39pm
Go with the WDH.  We pull with an Explorer with only a sway-bar and have had no problems even with cross winds that have exceeded 30 mph.  However the wdh will give a smoother ride and when we upgrade to a newer Explorer will probably get one ourselves.
Carlos&Alicia View Drop Down
Direct Link To This Post Posted: 24 Feb 2016 at 9:54pm
Welcome.  We too are owners of a 178 - 2015.
Carlos & Alicia
2015 RPod-178
1999 Cadillac Escalade
2005 Suzuki Boulevard C50
Newfoundland/Collie Mix (Max)
Shih-Tzu (Mia)
Chihuahua/Pug mix (Foxy)
CharlieM View Drop Down
Direct Link To This Post Posted: 21 Feb 2016 at 11:20am
Your Jeep GC has the muscle, but will still benefit from weight distribution. WD is separate from, but often combined with, sway control. I recommend both.
Tetoncamper View Drop Down
Direct Link To This Post Posted: 21 Feb 2016 at 11:11am
Thanks for the input and great advice.  My diesel Grand Cheerokee has a 7200 lb tow weight so should have the muscle for the mountains but issue of sway control is a concern.
DaveC3 View Drop Down
Direct Link To This Post Posted: 21 Feb 2016 at 9:39am
Welcome to the forum.  I am also a new owner, we will take delivery of our 180 this coming Saturday.  My wife will do most of the driving.  She has never towed anything before.  We are having the dealer install a Equal-i-zer 4-way sway control hitch.  My opinion error on the safe side.
Good luck.
Dave
2016 R-Pod 180
2015 Ford Explorer Limited
Direct Link To This Post Posted: 21 Feb 2016 at 7:57am
Yes, you should get a combination WDH + Sway control hitch. Two popular options are the 6000/600 pound E2 from Fastway and the Andersen hitch. WDH will greatly smooth out the bumps and dips while the sway control will help with crosswinds and passing trucks. Both will go a long way to reducing driver anxiety and fatigue. Fewer white knuckles Smile.
Direct Link To This Post Posted: 21 Feb 2016 at 7:37am
Welcome to the group!
Direct Link To This Post Posted: 21 Feb 2016 at 6:07am
   Yes! I think you will be much happier and feel safer. Even with a full size truck the difference in towing with a WDH is better. I don't think you will regret buying one after towing with it and noticing the difference.
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 20 Feb 2016 at 10:56pm
My opinion is that you should get a weight distribution hitch with sway control. What is the tow rating for your Grand Cherokee?
I have a 179 and use an Equal-i-zer 4-way sway control hitch rated at 6,000 lbs. We went from NC to NV and AZ and back to NC in December/January. I'm glad I had the hitch because it would have been a very different experience if I had tried with a normal hitch. We hit some high, gusty winds both on the way out and on the way back.
As I mentioned in another thread, it is better to have it and not need it than need it and not have it.
