  New Posts New Posts RSS Feed: Tongue height?
Topic ClosedTongue height?
howmanyds View Drop Down
Direct Link To This Post Topic: Tongue height?
    Posted: 19 Feb 2016 at 11:50am
Does anybody know the tongue height on new Rpods? I need to determine if I need to buy a riser or drop for my van's hitch.
john in idaho View Drop Down
Direct Link To This Post Posted: 19 Feb 2016 at 3:29pm
that is kind of a moving target.  You need to see how much your van drops down when you hitch up.  And how much stuff you have in the back of the van.
Direct Link To This Post Posted: 19 Feb 2016 at 6:52pm
Even if it drops down a bit, wouldn't I still want to start about level?
CharlieM View Drop Down
Direct Link To This Post Posted: 19 Feb 2016 at 7:13pm
It is a moving target. It depends on how much your TV sags and how much you correct with a WDH. Some TV sag will always remain.The end result should be towing the Pod level or slightly nose down. Close to level will allow you to stop overnight without disconnecting the Pod. When parked the refrigerator needs to be within +/- 3 degrees of level (Pod front to rear), but that becomes pretty obvious.
Akula1 View Drop Down
Direct Link To This Post Posted: 22 Feb 2016 at 10:02am
If you have a smartphone it has a Compass app that will allow you to see the level by placing it on the frame of the Pod.
2019 R-Pod 190
2019 Colorado LT
shroomer View Drop Down
Direct Link To This Post Posted: 22 Feb 2016 at 8:49pm
Start looking around 18". That's where my 177 was - it had the axle risers. It may vary depending on suspension squat etc., but it's a good  place to start.
Direct Link To This Post Posted: 23 Feb 2016 at 3:13am
Thank you!
