  New Posts New Posts RSS Feed: DUST
Topic ClosedDUST - Event Date: 28 Jun 2015
mikeyg2347 View Drop Down
Direct Link To This Post Calendar Event: DUST
    Posted: 28 Jun 2015 at 3:52pm
We just completed our maiden voyage in our 171. Drove about 6 miles on a dusty Forest Service Rd. and when we arrived at our campground were surprised to find a fine layer of dust covering the interior of the pod. Windows and vent were all shut tight. Anyone else have this experience? Any suggestions?
Mike
Mike
Direct Link To This Post Posted: 28 Jun 2015 at 4:16pm
We had that happen towing down a dusty road in Vermont. The tech at our dealership told us to crawl under the pod with a can of spray foam and spray it around where any wires/pipes etc go through the floor. He added that it will also help if you are in an area with a lot of field mice.
Direct Link To This Post Posted: 28 Jun 2015 at 4:38pm
Thanks. We'll give that a try. No dust got into the outside access storage so I'll start at the front.
Mike
scentralmt View Drop Down
Direct Link To This Post Posted: 29 Jun 2015 at 12:07am
I had dust show up in my 177 on the first trip on a gravel road.  That was last fall and I was using a catalytic heater so  had a roof vent and a window cracked open.  I found air coming out of the vent under the bathroom door.
When back home I removed the vent cover and saw that the drain pipes for the bathroom plumbing did not have any foam sealant around them.  I pulled the paneling below the door and used expanding foam around the pipes.
That has solved the dust and not doubt will help when running the heater since I won't have air being pulled in through those openings.
Curtis
Curtis
2014 177
2001 F150
Direct Link To This Post Posted: 05 Jul 2015 at 8:13pm
Interesting!
