  New Posts New Posts RSS Feed: Sanitize tank w/o bleach??
Topic ClosedSanitize tank w/o bleach??
David D View Drop Down
Direct Link To This Post Topic: Sanitize tank w/o bleach??
    Posted: 01 May 2015 at 1:17pm
Hi Everyone,
I've got a new 179 and per the, Forest River Travel Trailer/Fifth Wheel Owner's Manual, p.27, they recommend sanitizing the fresh water tank and lines with a bleach mixture.  Given that here in CA we are in a drought, can anyone recommend a bleach substitute?  I plan on dumping the spent cleaning mixture onto my yard plants and grass.  Would prefer not to use bleach for that purpose.
Thanks, in advance, for any suggestions.  Link below is explanation of sanitizing process from manual.
David
2015 R-Pod 179
Outbound View Drop Down
Direct Link To This Post Posted: 01 May 2015 at 3:33pm
Its best not to cut corners where safety is involved - I suggest sticking to bleach.  There isn't much available that reliably kills giardia, and a good, long bleach bath is still the best.
Bleach is biodegradable and likely the safest sanitizer you could use on your lawn.  Besides, you only need to use 1/2 cup of bleach - which gets very diluted in 35 gallons of water in your fresh tank.  Sure, your nose will detect it, but it really isn't very strong.
If you want to test it, 0.5 cup / 35 US gallons = 0.68 teaspoons / gallon (so... just over half a teaspoon).  Mix up a jug and test it somewhere inconspicuous on your lawn.
Direct Link To This Post Posted: 01 May 2015 at 3:40pm
Craig,
You're right, I hadn't thought about the dilution.  I only saw bleach and thought yikes.  Thanks for the reply, I appreciate it.
2015 R-Pod 179
hogone View Drop Down
Direct Link To This Post Posted: 01 May 2015 at 6:29pm
beer.  hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 01 May 2015 at 6:58pm
That would work!!
Direct Link To This Post Posted: 01 May 2015 at 7:13pm
So if I were to use beer..... would its hops and barley fertilize my lawn too?!?  What a brilliant idea!!!
2015 R-Pod 179
Direct Link To This Post Posted: 01 May 2015 at 7:27pm
Might perk up the vegetable garden too!
