HuronSailor ![]() podders Helping podders - pHp ![]() ![]() Joined: 10 Jun 2009 Location: Owosso MI Online Status: Offline Posts: 704 |
![]() Posted: 28 Dec 2014 at 11:31am |
Another possibility:
http://www.rpod-owners.com/forum_posts.asp?TID=2566&KW=&PID=24340&title=vertical-slider-in-door#24340
There is a better write up over in my mods folder, unfortunately on the other forum.. Page 8.. I really should try to move it all over here, this is a better, and way more active forum.. I just didn't know that when I started..
Linky |
Larry158 ![]() Groupie ![]() Joined: 01 Oct 2014 Location: Old Forge NY Online Status: Offline Posts: 45 |
Furpod,
Thanks for the info & the encouragement to install by myself. Larry158
It's a no-brainer to instal. Find a window that fits, and you like, the door is an inch and a half thick. Layout the spot you want it with tape, drill hole, cut with jigsaw, instal window. Took an hour.
Travis & Carrie,
Thanks for the info. Will begin to look for a tinted window that has a sreen in it. If anyone has an idea of where to get such an item & a possible lead for an installer. Thanks again Larry158
kymooses ![]() Senior Member ![]() ![]() Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
It voids the warranty on the door only, not the R-Pod. Forest River has approved this mod and know that a lot of us do it.
I queried my dealer re installing a window in my door (2015 178) for safety reasons & was informed that my warranty most probably would be null & void should I take such action. I do not understand why the Rpod does not come with a door already installed.
Any one come across this situation to date? Larry158
