johnmaci ![]() Senior Member ![]() ![]() Joined: 17 Jun 2014 Location: MD Online Status: Offline Posts: 202 |
![]() Posted: 20 Nov 2014 at 1:26pm |
Exactly. It attached perfectly since they are also Anderson Power Pole connectors.
I would highly recommend the extension cable, since it has come in handy for me in more than one situation. The tow wiring harness adapter is convenient, but not a must have if you have easy access to your battery to use the clamps. |
Hi johnmaci. I'm just curious if you got this Go Power! 7 pin adapter? Looks pretty nifty and an easy hookup for any trailer. Thanks, fred |
Great minds think alike :)
I also went with a 100W portable Renology, and it has been great! http://www.amazon.com/Renogy-Foldable-Suitcase-Battery-Charger/dp/B00HR8YNK6/ref=sr_1_1?ie=UTF8&qid=1416485901&sr=8-1&keywords=portable+solar I also purchased an adapter (another online vendor), that allows me to connect directly to the tow wiring harness and not have to use the post clamps; and extension cables in case I am parked in a shady lot, and can move the panels a good distance away to get to the sun. If you are new to solar, there is a lot of information on the net and videos on YouTube on how to position for best performance. 1. I always use a compass, and point the panel to true (geographic) south and not magnetic south accounting for any magnetic deviation. 2. I use this calculator to find "solar noon" for any geographic position: http://www.esrl.noaa.gov/gmd/grad/solcalc/ 3. Finally, I use this digital angle gauge to get the most accurate angle on my panel: http://www.amazon.com/gp/product/B001PTGBRQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 This article has a good explanation on how to also use the "shortest shadow" method instead of using an angle gauge for your location: http://rimstar.org/renewnrg/finding_true_south_pole.htm |
SiberD ![]() Newbie ![]() Joined: 07 Oct 2014 Online Status: Offline Posts: 33 |
Eventually I would like to get solar for our's too. I was looking at this kit...
http://www.amazon.com/dp/B00HR8YNK6/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1JLWN8CB2QJDV&coliid=I3O4N29H1F2XQB And then get a connection like this.. http://www.ebay.com/itm/360693403228?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT and use butt connectors and shrink tubing for a direct plug and play. |
fixitmr2 ![]() Newbie ![]() ![]() Joined: 13 Nov 2014 Location: Liverpool, NY Online Status: Offline Posts: 7 |
I'd like to thank everyone for their ideas on the solar power.
When my wife, Linda first saw the Rpod 179 her eyes just lit up so I knew we were buying one. Ron and Linda |
Ron and Linda
2015 R Pod 179 2015 Tacoma |
kylekai ![]() Senior Member ![]() Joined: 06 Aug 2014 Location: San Diego Online Status: Offline Posts: 139 |
I have a 179 and purchased a Zamp 80 watt solar panel. Works great, just plug and play.
Found the best price at eBay: http://r.ebay.com/KyHRYM
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
Greeting and Congratulations on your 179 acquisition!
Yes, this is my understanding. The "solar connection" is just a plug with 10g wires that run up to the battery. I plan to verify this some time with a simple continuity test. So yes, it would seem plausible that other systems can be used. The Zamp products are plug and play and come with a premium charge controller and fused feed lines so, of course, you will have to add those to your panel or buy a kit that includes them. Good luck!
Cliff & Raelynn
Welcome to the group!! Hope you enjoy your 179 as much as we enjoy ours!!
RescapePod ![]() Groupie ![]() Joined: 14 Sep 2014 Location: Charleston WV Online Status: Offline Posts: 45 |
welcome..we have the 179 with solar and my research here on the site shows that the setup is just a direct connection to the battery to charge the battery. That is a good thing because you CAN use other brands of panels to charge the pod as long as the connector at the port is the same. Do a search on here and you will get lots of information as well as pros and cons of solar.
2015 R-Pod 179
2013 Chevy K1500 |
We recently bought an RPod 179 and love it. Question I have, is do you have to purchase Zapp Solar Panel or can you use any solar system with the Zapp connection on the RPod?
Ron and Linda
