  New Posts New Posts RSS Feed: Towing with a Tacoma
Topic ClosedTowing with a Tacoma
2McPods View Drop Down
Direct Link To This Post Topic: Towing with a Tacoma
    Posted: 29 Aug 2014 at 8:19am
Hello, we have the 2015 171 pod and plan on pulling it with our 2003 Tacoma 4x4 4cyl. When I say plan to, right now ours is in the shop having the frame replaced that rusted out and was a recall, thank God.
We have a loaner 2013 Nissan Frontier 4x4 6cyl. that pulls it pretty good. Anyone have any helpful info we could use for the Tacoma? Thanks
Everything Happens 4 A Reason
Pat & Viki McCartney
2015 171 {2McPods}
2014 F150
Pittsburgh, Pa
BerryMt View Drop Down
Direct Link To This Post Posted: 29 Aug 2014 at 7:20am
Thanks! we are considering the 179. Seems to contain everything we need.
BerryMt
M3 View Drop Down
Direct Link To This Post Posted: 28 Aug 2014 at 8:51pm
I pull my 178 with a 2013 Tacoma 6 cyl, 4 wheel drive, long bed.....no problems whatsoever!
Mary and Tucker (my sheltie)
2015 r-pod 178 (lilypod)
2013 Toyota Tacoma
jeeperic View Drop Down
Direct Link To This Post Posted: 28 Aug 2014 at 10:22am
Hi BerryMt,
Sounds like you're on the right track with the mods to your Tacoma. What size is your 'Pod?
I am towing a 171 with a Wrangler (3.8l) and put in a brake booster with no problem. I was worried about the tongue weight of 225lbs maybe squatting down the Jeep, but again, it had no problems. Being the smaller 'Pod it pulled it okay, not fantastic with the wrong diff ratio, but just okay.
I did a quick image search on Google 'Tacoma with Rpod'. Looks like you're not alone on the road with your 'Yota / Pod combo!
Your Tacoma's tow capacity is 3500-5000lbs (depending on tow package/trim level/2wd vs 4wd, etc etc)
You're fine....happy camping!!
Eric
That's the power button..press it.
Turn it all off.
Go outside!
'14 RPod 171
'09 Jeep Wrangler JK (mine)
'14 Dodge Ram 1500 4x4 (hers)
Direct Link To This Post Posted: 26 Aug 2014 at 7:16am
Hi   we have an 04 Tacoma 3.4  V six engine TRD  4WD truck.  Has anybody had any experience towing an R Pod with this  truck?  I plan on installinf heavy duty rear shocks, transmission cooler, and brake controller.
BerryMt
