Page <123> |
Craneman ![]() Senior Member ![]() Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
![]() Posted: 09 Aug 2014 at 4:41pm |
Jo and Gary 2010 174 2011 Ford 150 |
Tman ![]() Newbie ![]() Joined: 23 Jun 2014 Online Status: Offline Posts: 5 |
Nice job Craneman, love the big handle. RK, yes I just bought the Rustoleum Rattle can (for plastic) and painted it. Used semigloss...
RKTodd ![]() Newbie ![]() Joined: 14 Jul 2014 Location: Indiana Online Status: Offline Posts: 12 |
Guess I quoted the wrong person
Randall & Rhonda
2014 RP-179 |
Were you able to find black fence posts, or did you paint yours. I can't find black anywhere, not even on Home Depot's website. Thanks!
Randall & Rhonda
2014 RP-179 |
This is what I did
Moe
svskier ![]() Newbie ![]() ![]() Joined: 24 Dec 2013 Online Status: Offline Posts: 29 |
Tman
If your out there listing, exactly which bolts did you use to connect the 5x5 post to your pod ? Thanks in advance and safe travels . Mark |
Mark
09 silverado 2500 hd 2013 pod 178 |
That makes perfect sense. Thanks, Bob. Yeah, getting/keeping the hose "clean" is a challenge.
Sleepless ![]() Senior Member ![]() Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Fred, I can't answer your first question. I have had my HydroFlush for many years, long before built-in black tank rinsers were available, and even then I would rinse out the grey water tank while I was at it. I still rinse out my grey water tank, although it is probably not necessary. But more importantly, I use the HydroFlush after I close the grey water valve. The strong flow of water flows through the sewer hose, really flushing the hose clean, much cleaner than by just letting the grey water flush it.
Prior to removing the sewer hose from the black water valve, I use the same procedure so the hose is "almost" sanitized before I move it to the grey water valve. (Yes, I realize that flushing the hose does not sanitize it, but it makes it more pleasant to handle). BTW, there are at least 2 models of the HydroFlush, one has a 45 degree angle, the other a 90 degree angle. I use the 45. Bob |
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Sleepless, do you think the HydroFlush would fit in the same Sanitube as the clear connector? I'm curious also at the need to flush grey tank?
Tanks. fred
I strongly recommend the HydroFlush. It has all the advantages of the clear connector but enables you to flush the grey water tank and hose, which you normally would not do. |
Page <123> |
