bcmatell
Topic: pump for water Posted: 10 Jul 2014 at 6:45pm |
Hi all, Question?? City/fresh water tank is over half full. We are dry camping, when I turn the water pump on and turn the sink tap on the water barely comes out,gurgles and sputters . I hope I spelled that right,LOL.
Whats wrong?? Need help
Craneman
Posted: 10 Jul 2014 at 8:14pm |
Do you get water anywhere else??? Shower ??? Are you sure you have water in the tank??? Some times the gauge lies
Moe
Jo and Gary
2010 174
2011 Ford 150
bcmatell
Posted: 10 Jul 2014 at 9:23pm |
Have not checked shower but will do that and yes I have water in the tank about 2/3 full
marwayne
Posted: 10 Jul 2014 at 9:38pm |
Is your winterization valve closed if not, you are sucking air.
ron_whitt
Posted: 10 Jul 2014 at 10:08pm |
Also take off areoator off of tap and clean it. It only takes a very small piece of dirt to block the water coming out of the tap... Take care to remember what order you took it apart.
Ron & Shirley
2020 Tacoma
2012 177 rpod
Old Dingo&Mrs.Dingo
Posted: 10 Jul 2014 at 11:29pm |
There is a plastic "filter" on the inlet side of my pump. If the cap isn't tight enough the pump pulls air, hand tighten should be enough.
Old Dingo and/or Mrs. Dingo
181G
2013 Jeep Grand Cherokee
Budward
Posted: 11 Jul 2014 at 5:54am |
I noticed on mine when I drain the fresh water tank after arriving back home from a trip- the next first use is gurgly and sometimes the pump doesn't want to shut off. After a few minutes and opening and closing a faucet it purges the air, clears up and works fine. Never had that in other RVs I've owned and am a little puzzled by it in the rpod.
2014 179
