Page <123 |
jmsokol ![]() Groupie ![]() ![]() Joined: 21 May 2014 Location: Maryland Online Status: Offline Posts: 89 |
![]() Posted: 16 Jun 2014 at 8:45pm |
I personally think it's best that all 120-volt AC systems have a G-N bond. So if your shore power connection DOES supply it, and your portable generator DOESN'T supply it, then YOU should supply it with an external G-N bonding plug. Just a reminder, this does NOT plug into an outlet inside of your RV. It must only be plugged into a spare Edison outlet on your Generator. FYI: All generators that are built-into larger RVs already have the G-N bonding function supplied by the transfer switch. Since you don't have a generator transfer switch in your "Pods" then this takes the place of one. |
mike@noshockzone.org
www.noshockzone.org |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
A modern inverter generator arguably probably doesn't need a surge protector. I'm sure there a scenarios were it might be a good idea with such a generator, but the thing is, if you permanently install a surge protector for those times when you're using no telling what kind of shore power, you're stuck with having it inline when you're using the generator. It's simple and cheap to do the G-N bonding plug. TT |
FJ Cruiser |
Camper Bob ![]() podders Helping podders - pHp ![]() Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Aha, said the blind man. I got it. So off to the hardware store for an openable plug and will put in the jumper and plug it into one of the Edison plugs. Never knew they were called that. Safe Travels.
Camper Bob and Camper Sue
Cookpod ![]() Newbie ![]() Joined: 09 May 2014 Location: Nor Cal Online Status: Offline Posts: 5 |
Just want to say thanks for the contributions here. Learning a lot and appreciate the posters willing to share their knowledge.
Cap-n-Cray ![]() Senior Member ![]() ![]() Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
A wall plug is called a duplex outlet or duplex receptacle...
Cary
2014 RP-177 |
Yes, pro-sound guys call them Edison outlets and plugs in America since that's the man who invented them. But you electricians and engineers also know they're officially called NEMA 5-15 or 5-20 connectors. ![]() http://en.wikipedia.org/wiki/NEMA_connector |
Page <123 |
