stevei54 ![]() Newbie ![]() Joined: 16 Feb 2014 Location: United States Online Status: Offline Posts: 7 |
![]() Posted: 16 Jun 2014 at 7:38am |
How did the replacement mount look covering up the holes from the factory mount?
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
I wish my 179 didn't have the TV already- the mount FR uses is lousy since, as mentioned, one can't tilt the antenna for proper viewing angle when lying in bed.
Even worse the FR supplied TV is 110 V ONLY, doesn't work on 12V. I could have DIY'd a better system for half the money- caveat emptor. |
2014 179
retireclose ![]() Groupie ![]() Joined: 19 Jan 2014 Location: Michigan Online Status: Offline Posts: 50 |
The 19" is okay for us. It's just the two of us and we don't watch alot of TV
Gary and Jill Winters
Bella Golden Retriever 2014 Silverado 1500 2015 R-Pod 179 -(SOLD) ![]() |
davewg ![]() Newbie ![]() Joined: 03 Jan 2014 Location: United States Online Status: Offline Posts: 15 |
Great tip on the mount. Thanks.
Does the 19" feel big enough, or would something a little larger be better (say 22").
We have a 179 and the TV was mounted. The mount they use has no up/down movement just side to side. We replaced our mount with a full motion mount
"VideoSecu
TV Wall Mount Articulating Arm Bracket for most 12"-24", some up to
27" with VESA 100/75mm LCD LED Flat Panel Screen TV and Monitor ML10B 1E." from Amazon for $ 14.99. Works great.
Hi All -
We're looking at purchasing an RP-179. One of the units does not have the Jensen LCD TV installed and the dealer would have to mount it. Is the TV normally mounted/installed by the dealer, or are some models just equipped that way from the factory? I assume it really doesn't make a difference whether its dealer installed or done by FR, but wanted to check. Thanks.
