rimshot
Topic: Generator Question??? Posted: 13 Apr 2014 at 12:21pm |
I'm still getting the Pod ready for our first trip but a lot of campgrounds are already full for the season. We ended up with two dates booked but the first trip isn't until June. Which leads me to the generator question. I know some places up hiway 108 on the north side of Yosemite where you can just pull off the hiway, drive a short distance up dirt roads and set up. Central to fishing and gold panning, which I love to do. I have a generator, Toro T800, that would only run a couple lights itself, but is great for charging batteries. About twenty years ago I sold my 1976 Aristocrat LoLiner so I just kinda forgot about the generator. I did turn the gas off and let it run out, but didn't empty the tank. I'm now going through it to use it again and when I pull the air filter out, it crumbled in my hands, and you guessed it, they're no longer available. Is there something else I can use for a filter, or could I maybe buy a lawnmower filter and cut it to shape? By the way, the old gas looked and smelled like I bought it yesterday.
Posted: 13 Apr 2014 at 8:54pm |
Pre-ethanol gas was different I guess, but not so different that I'd trust it to run through the carb. I'd pour it out and put some fresh non-ethanol gas if available and I'd try it out without the air filter before spending any money on the air filter. It won't hurt to run in a clean environment without a filter for a while. You might need a little choke.
As for the filter, if it's just a regular foam filter, I don't know why you couldn't cut one out of a larger filter. Google around for a while to see if you can't find one ready made.
rimshot
Posted: 13 Apr 2014 at 9:23pm |
I did pour all the gas out, added a little fresh gas, shook it a little and dumped it out too. Changed the oil and have a new plug for it. I was told to put about a tablespoon of oil down the plug hole and pull the cord slowly a few times before I put the new plug in and try to fire it up too, but I haven't got around to that yet. I don't think I'll need the generator much, but if I do decide to start boon docking it may come in handy.
Sleepless
Posted: 13 Apr 2014 at 10:46pm |
One more possible consideration. Here in Florida we have been experiencing fuel line problems with outboard motors built during the pre-ethanol days. Ethanol will slowly deteriorate rubber fuel lines, causing all types of problems. Fortunately, gas lines are easily swapped out. I have an older Coleman 1750 generator and the fuel lines are beginning to fail, causing clogs in the carburetor jets and gradually deteriorating in general. I will be selling this generator, but not until I replace the fuel lines. Total cost, about $1.00.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Budward
Posted: 22 Apr 2014 at 9:03pm |
I know from my dirt bike days one can buy sheets of foam filter material and make whatever you want. Uni is the brand I've used.... I had to make a filter for a 600watt Honda generator I bought in the mid 70's as the original finally disintegrated.
Outbound
Posted: 22 Apr 2014 at 9:43pm |
Good idea to cut down a foam air filter to fit. I'd also suggest:
- change the oil (don't even try to start it without changing the oil first)
- dump the gas. actually, i'd drain it and put it in my vehicle to use it up
- replace the sparkplug
- add some SeaFoam to the first tank or two of gas
