  New Posts New Posts RSS Feed: Wet Batteries
Topic ClosedWet Batteries
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Wet Batteries
    Posted: 05 Apr 2014 at 10:29pm
So with 12v batteries in parallel, both negative posts go to the chassis?  (Rather than one negative connected to the other negative and then to the chassis?)
But wouldn't the positive terminals be connected to each other with one cable to the fuse box?  So why disconnect them both?
wingnut2312 View Drop Down
Direct Link To This Post Posted: 05 Apr 2014 at 11:09pm
So I know this may sound like a dumb question, but....why is it necessary to have distilled vs tap water? I guess the water keeps it cool. If not, why the water? Conductivity? I hate electricity unless it persuades answers...
2014 rpod 182G
Ford Expedition
kymooses View Drop Down
Direct Link To This Post Posted: 06 Apr 2014 at 11:37am
the extra minerals and things in your regular house water can build up on the plates.  plenty of folks use regular tap water with little noticeable harm if any at all.
i suppose depending on how hard the water is where you are could change that a lot.
that being said, i have distilled water in the garage to check mine and only use that.
rimshot View Drop Down
Direct Link To This Post Posted: 06 Apr 2014 at 11:44am
I will be drilling the holes in both boxes. Easy fix. I'm also going to investigate the possibility of using a perko switch for the batteries. Might just work. In the mean time I'll just plug it in every weekend since it's in the driveway. Thanks for all the help....Bill
CharlieM View Drop Down
Direct Link To This Post Posted: 06 Apr 2014 at 1:54pm
Generally the two negatives would be strapped together and only one battery connected to the chassis. Likewise the two positives would be strapped together and only one battery connected to the trailer power panel. The two trailer connections
should be to opposite batteries to perfectly balance the circuit impedance. The reason for disconnecting both positives or both negatives is to prevent discharging one battery through the other one. However, this is really a minor effect. Probably way less than the self discharge rate of each battery separately. Jump in Doug if I'm of base on this.
