Page <1 34567 12> |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1060 |
![]() Posted: 03 Mar 2014 at 9:20am |
Thanks huron, that is exactly what i was looking for.
Jon & Pam
HuronSailor ![]() podders Helping podders - pHp ![]() ![]() Joined: 10 Jun 2009 Location: Owosso MI Online Status: Offline Posts: 704 |
I'm looking for one for myself now. Just found this at Home Depot:
http://www.homedepot.com/p/PowerFit-Outlet-Adapter-30A-240-Volt-To-30A-RV-PF923055/203213234 For under $20 I might try this. I'll ask an electrician buddy of mine first.
OK, let me know. I appreciate all the info.
Jon & Pam
Sleepless ![]() Senior Member ![]() Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
I normally use the cord that came with the generator. Each of the 4 terminal cords is 120 volts, and I use that cord to run from the generator to the inside of the house. From there, I run extension cords to whatever I want to power, usually lights, a small TV, etc. I keep one free, which I will plug into the refrigerator, microwave or the electronic ignition of our gas range. I never run the micro or refrigerator at the same time. That "split" cord eliminates running several separate extension cords from the generator, and it is heavy gauge which eliminates overloading cords at the generator. |
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Here is what I am planning to do in my house. Install a dryer vent plug (220 V) outside the house run, a 30 AMP wire to the dryer vent plug in the house. Trip all breakers including the main breaker, your power now comes in the house through your dryer wiring to the breaker panel. Now you can control your power by selecting breakers to be turned on and off.
Since my big genny is 30amp, I just built a cord that plugs into my welder circuit. But other than that, we do it the same. I made up a laminated card with instructions and hung it in the breaker box. (just in case I am not here when it's needed) |
Yeah I agree it helps a lot if your breakers are marked.
I guess what keeps tripping me up is this receptacle on the gen is 240/120; not 220/110...........again I'm pretty green on this electrical stuff. So if I am understanding all this correctly (again I'm talking about hooking up to the pod); if I purchase this adaptor as mentioned above by Huron and plug the pod cord in; is it just like hooking up to a 30 amp outlet like in a campground?
Jon & Pam
Huron: Amazon has a camco cord (55382) for 26.03
Jon & Pam
hogone, this might help.
My setup... Cord: male end to 30 AMP generator port: ![]() 30 AMP Port on outside of house: female end of cord ![]() Transfer switch panel next to and wired to main breaker panel: ![]() My routine is to hook cord up, start generator, go to transfer switch all breakers to generator. Not quite automatic, but not bad...and safe. I've been pretty good at guessing when the power might go out, so I hook the generator up and if the power does go, I simply push the start button on the generator and switch the breakers to generator. I do keep one (light) circuit on mainline power so I know when the power comes back on. I have a neighbor that didn't realize power was back and ran his generator for two days after power had been restored! Hope that helps. fred
Page <1 34567 12> |
