wingnut2312
Topic: towing Posted: 30 Aug 2013 at 6:28pm |
Thanks! Feel free to let me know anything that could make it more fun!
GA_RPOD_178
Posted: 30 Aug 2013 at 4:40pm |
Originally posted by wingnut2312
Well we were just approved today for our rpod 182G! You are both correct on the brakes. You are responsible to know and abide by the state you are in's laws and regs. MI does require, so I'll have to check on the uhaul.
Thank you all for the info. It helps to have a place to go when you are uninformed. |
Congrats and "officially" welcome to Rpoding!
 [/URL]
wingnut2312
Posted: 30 Aug 2013 at 2:14pm |
Sleepless
Posted: 30 Aug 2013 at 2:05pm |
Charlie, I was towing when I lived in Michigan and the common understanding there was that an electric brake controller was acceptable because it is applied by the operator pressing the brake pedal, the same as the vehicle's brakes are applied by the operator when he or she depresses the brake pedal. It is also my understanding that if you tow a trailer through a state that has more stringent trailer brake requirements, you are bound by them as long as you are within that state. Here is a link to the requirements in every state.
http://www.boatwheels.biz/brakelaws.pdf
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
CharlieM
Posted: 30 Aug 2013 at 1:33pm |
Bob,
Interesting input on the MI regs. I have seen that 40% in other states too. It really doesn't help us since, taking my Honda for example, 6100# GVWR, a brakeless trailer could not exceed 2440# GVWR. Take away your "stuff" and you don't have much left for the empty trailer.
The last sentence is interesting: "Trailers 5,000 pounds and over shall be equipped with brakes designed to be applied by driver of towing vehicle."I guess that eliminates hydraulic surge brakes, but does it allow electric operation by the brake pedal or does it force a manual overide like we have on our Prodigy controllers?
Sleepless
Posted: 30 Aug 2013 at 11:42am |
Seems like we are all guessing about if the U-Haul pickup trucks have a 7-pin Bargman connector and an electric brake controller. A call to your local U-Haul dealer should give you the answers. CharlieM is absolutely right about the trailer brake requirements in Michigan. However, the law is even more stringent it you look at the exception I have pasted below. And, without electric brakes, don't even think about taking your pod to your neighboring state of Wisconsin. These comments are offered as constructive, and I hope you accept them as such. MICHIGAN 257.705.28.1479 Sec. 5.79 3, 000 All n/s Trailers less than 3,000 pounds gross weight need not be equipped with brakes if gross weight of trailer and load do not exceed 40% of gross weight of towing vehicle. Trailers 5,000 pounds and over shall be equipped with brakes designed to be applied by driver of towing vehicle.
Bob
wallawallaron
Posted: 30 Aug 2013 at 10:20am |
My F150(2010) has integral brake controller along with 7 pin and 4pin set ups factory tow package. WWR
When you say the U-hauls are "equipped", do you mean with an integral brake controller as mentioned above? If so, they must have a 7-pin Bargeman on the back and not a 4-pin connection. No 7-pin, no brakes, even if the controller is in the dash. [/QUOTE]
WallaWallaron,2012 RP177 H.R.E.,2010 F-150.NRA Life Member
9/11 Never Forget
Posted: 30 Aug 2013 at 10:10am |
The wireless Prodigy is the only one that would not modify the truck, if done as I suggested. All the rest require 3 wires to be run to the brake controller and then it outputs 1 wire which must be run back to the 7-pin Bargeman. Two of the 3 wires could be taken from a lighter/outlet, but the tricky one is the connection to the brake light wiring and there's no way to do that without finding the right wire and splicing into it. You can't even tap that signal at the 4-pin connector at the back of the truck because that output also includes turn signals. You would end up activating the brakes any time you made a left or right turn.
wingnut2312
Posted: 30 Aug 2013 at 9:38am |
Lol, hopefully more without than with. I have found that I can use a non-modifying brake controller. The Uhaul F-150's are "supposed" to be equipped. We shall see!!
CharlieM
Posted: 30 Aug 2013 at 9:29am |
Wingnut2312: Let me say I commend you for asking questions and seeking the advice of those who have been there. It's the way I learned and, probably, most others too. As you can see many of our opinions are strongly and loudly professed. Please credit this to enthusiasm, not animus. We all think we have the answer, some of us really do.
After following your conversations with your dealer I'm alarmed to see him in the business. From what I see he's gotten everything wrong and dangerously so. I'd suggest an immediate dealer transplant. BTW, MI requires independant brakes on trailers 3000# or greater Gross Vehicle Weight Rating (GVWR). This is the sum of the empty trailer plus total allowable load. All versions of RPODs exceed this threshold.
Welcome to the forum and and I look forward to hearing of your adventures, with or without the orange UHaul.
