TopJimmy5150
Topic: towing Posted: 12 Aug 2013 at 11:53am |
I also tow with the tanks dry, FWIW.
Jay
2014 R-Pod RP178
2015 Toyota Tundra SR5 Crewman
2008 Honda Odyssey
Seanl
Posted: 18 Aug 2013 at 10:10am |
Originally posted by Kokopod
Yesterday we traded in our 2012 Jeep Liberty Arctic, because when we pulled our pod in extreme conditions (heat, wind) the transmission would overheat. Jeep does not make a Mopar transmission cooler for the Liberty, and installing an aftermarket would have voided our lifetime warranty.
We loved our Liberty; but when we purchased it, we owned an Aliner that was 1,000 pounds lighter than the Rpod. Add cargo, etc. and we were at just about max capacity (we use the Equalizer 4-point sway control and never felt unsafe about the actual tow, although SLOW was the word). We were in denial from last November (the first two times we overheated) until last month in Nevada with temps of 110 (two more overheats). When we took it into the dealer, they had to change the transmission fluid after only 30,000 because it was already dark. If we weren't overheating and if we could have added a transmission cooler, we would have the vehicle today, but you have to do what you have to do to be an Rpod owner. |
I have a 2009 Liberty and it came with a stock transmission cooler. I wonder if you could have just put in another stock cooler as an auxiliary . The only time I have overheated the transmission, here in the great white north, was when I was jockeying the trailer around my yard in 4x4 one day. The Trany cooler is not in line with the fan so if you are not moving fast enough to get air over the cooler it heats up.
Kokopod
Posted: 18 Aug 2013 at 2:53pm |
Oh, if only! We called Chrysler the first time it happened last October, they said NO! When it happened this time we called Chrysler. They said NO. The mechanic at our Chrysler dealer called - NO!
2017 Jayco Melbourne 24k
2013 Premier 19FBPR
Formerly-2013 R-pod 177HRE
2011 Dodge Durango
Love a good road trip
Kokopod
Posted: 18 Aug 2013 at 2:55pm |
By the way, ours had the full tow package! Obviously the full tow package was a wee bit lacking.
2013 Premier 19FBPR
2011 Dodge Durango
HuronSailor
Posted: 18 Aug 2013 at 4:15pm |
Just an FYI here as to camper weight. I recently took a tour of FR's rpod/Surveyor factory, and as a final step every camper is weighed. The weight includes every factory installed option as well as the empty propane tank. rPods don't ship with batteries, so that weight is not included. Air conditioners and microwaves are normally installed at the factory, so that weight is in fact included.
The weight printed on the screen door sticker is the weight of that individual camper as it leaves the factory door.
Sleepless
Posted: 18 Aug 2013 at 7:40pm |
Originally posted by HuronSailor
The weight printed on the screen door sticker is the weight of that individual camper as it leaves the factory door. |
I had my doubts, but this checks out. My pod's specification weight is 133 pounds less than shown on the screen door. That should be about right.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Chops
Posted: 18 Aug 2013 at 9:55pm |
we tow a 178 with a honda odyssey. No problems but we did make some modifications to make towing easier on the Ody. FYI the dry weight on the door was 2926 I believe....
Sleepless
Posted: 19 Aug 2013 at 9:02am |
Just for weight comparison purposes, my 173's sticker shows 2172 pounds.
Bob
GA_RPOD_178
Posted: 19 Aug 2013 at 9:10am |
Bob
The "screen door weight" for our 2013 178 was 2745.
 [/URL]
HuronSailor
Posted: 19 Aug 2013 at 11:33am |
Here's a site which explains all the different numbers on an RV:
On this site it says the manufacturer itself defines how UVW (we're calling it screen door weight) is figured. The Unloaded Vehicle Weight of an RV can be an average or estimated weight for each model. It can, but may not, include factory installed options, or it may include only the most commonly ordered options. It also says that some manufacturers weigh each unit to determine the UVW. This is the case at Forest River's Rpod/Surveyor plant. They actually park each unit on a scale and print the sticker just before it goes out the door.
The screen door weight of our 2009 172 is 2330#. That included every available factory option except risers. The Gross Vehicle Weight Rating of my model as stated on the sticker on the left front of the pod is 3179#, which means I can load 849# of stuff before I hit the maximum. This "maximum stuff" number is also printed on the door sticker.
I've noticed that the slide out models are hundreds of pounds heavier than our model. This must mean these models use a different axle than the Lippert model on my pod, and their GVWR must be higher than mine. True? I know they have a couple of axle suppliers.
