List Your Mods:
 Post Reply Post Reply Page  <1 6364656667 78>
Goose View Drop Down
Post Options Post Options   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 01 Aug 2013 at 5:35pm
Looks nice! Nothing like making it your own. Goose
KrogPod View Drop Down
Post Options Post Options   Quote KrogPod Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2013 at 3:10pm
Not to many mods on our KrogPod RP-172 as we have only had it just over a month but we have many planned. Nothing really original here just variations form what others have done.
Mods so far;
Cut seat platform by sink so it can be opened without moving rear cushions.
Cut access hole under lower bunk near door for access to Sodas and water with stop blocks so items don't slide around while traveling and put trim on opening for appearance and protection.
Also split the bunk support board for easier access over the top.
Added small railing to cabinet above oven.
Additional foam on both bunk mattresses. No photo but used 1.5" 38lb foam.
Installed mirror on inside of bath door using Command Strip Velcro, mirror from Target $5.98.
Installed padding on top bunk support, that thing was a head knocker.
This photo from under top bunk showing padding protrusion.
Fabricated stove cover/cutting board. Also works as a splatter guard when using stove.
Installed wire shelf for bath soap and shampoo bottles, doubles as TP holder.
Several more are planned;
Small shelve above side windows
12" Porthole window in door
Misc. cubbies near door for flashlight, binoculars etc.
TV/Radio, very poor reception on Tv and radio, needs external radio antenna.
2014 RP-172, AKA KrogPod
2003 S10 ExCab V6 4.3L Automatic
Central Texas
Sleepless View Drop Down
Post Options Post Options   Quote Sleepless Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2013 at 3:10pm
Nice work!  Just curious, but was there a wood cross member in the ceiling where you anchored the cleat?  I do like the location.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Post Options Post Options   Quote furpod Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2013 at 12:08pm
Latest mod was to move the TV to a spot it's actually viewable while in bed. This is the only place we watch TV from/in, if we watch TV. In the stock mounting location, it's way to close to you, and it can't actually be tilted to view well. So I removed it from the bottom of the center head bumper cabinet (though we have never bumped into it, many report doing so...)
Hung some cleats on the side of the shower enclosure and rear ceiling, cut a shelf and added a lip, placed a 120v outlet left over from the iPad charger mod to the shower wall, taping into the power running down to the outside outlet. The shelf is also supported by the valance, which I remounted to make sure it was firm and screwed into the aluminum framing studs of the outside wall.
Zag View Drop Down
Post Options Post Options   Quote Zag Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2013 at 7:24pm
Here's my over the stove top solution. It's made of scrap 3/4" plywood counter top that I got free from a local cabinet manufacturers junk pile, some pine and a set of rubber foot stoppers. All said and done, less than $10 to make.
Followed the suggested dimension of 16x20x2 and pretty satisfied with the results. The other side is white laminate. Still trying to figure out how I'm going to hang it to the side of the counter when I'm using the stove. Any suggestions?
2009 RP-152 (Cutie-Pod)
2001 Nissan Pathfinder
Chessies View Drop Down
Post Options Post Options   Quote Chessies Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2013 at 5:48pm
In my quest to make things harder to steal from the R-Pod i have locked the battery case, used a heavy-duty cable on the propane tank, bought matching coupler pin and coupler locks, and installed McGard wheel locks on the wheels. The last easily snatched item was the spare tire. First I installed a locking receiver pin on the spare tire carrier receiver. My spare tire bracket came with two 1/2-in bolts welded to the carrier--one to fit through the top hole of the spare tire, the lower to tighten down a bar across the lower part of the wheel. Regular 1/2-in nuts were used so that the wheel didn't seat well and the lower bracket scratched the wheel. To fix this I first cut out the bolts, replaced the upper one with a 1/2x20 wheel stud (the same size as the axle studs). Next I welded a short piece of angle iron across the lower bracket and drilled holes to weld new 1/2x20 studs to fit two lower wheel holes. I then installed the spare with one of the McGard wheel locks and two spare nuts. Hopefully the photos explain what I'm trying to describe (please excuse my ugly welds). At any rate, someone may steal the whole trailer but at least casual theft of component parts is discouraged.
Jim & Christine
Buddy & Dougal the Brown Dogs
R-Pod 171 (2013 Hood River Edition)
2004 Toyota Tundra
gasman50 View Drop Down
Post Options Post Options   Quote gasman50 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2013 at 10:49pm
Hello everyone. A newby here, and two months ago I got a new rpod 178. The wife and I love it. One problem was no music. My Flagstaff A-frame came with a nice radio so I was spoiled. Here's what I did. Got a Kenwood car Stereo, Two Boss speakers a antenna and a power switch all for $100.00, Now the hard part. Making holes in the NEW camper. I had to build a box for the radio so it would come out from wall so it would fit. Not much space behind entertainment center because (Shower is there) took my time running speaker and power wires and it sounds great. one day I might add an outside speaker.er
2014 RPOD 178
Zag View Drop Down
Post Options Post Options   Quote Zag Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2013 at 6:59pm
My first (of many) mods on my Pod.
The link on Ebay to buy a custom decal is: http://www.ebay.ca/itm/180679160933?_trksid=p5197.c0.m619.
2Poders View Drop Down
Post Options Post Options   Quote 2Poders Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 8:39am
Great way to use the space. We could use more storage
Randy and Anne
2011 R-Pod 182G
2009 Highlander V6 AWD
Racer|X| View Drop Down
Post Options Post Options   Quote Racer|X| Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2013 at 7:07pm
Very nice use of the space.
