bc matell
Topic: Anode Rod Posted: 05 May 2013 at 6:04pm |
The pod is not a year old yet. QUESTION-----The anode rod from the hot water tank is what I am having a problem with. I have it threaded half way in but then it gets VERY hard to screw any further. Have tryed many times. I don't want to force it. Any clue to what is wrong???
I don't want to go to the dealer yet. Any help is always greatl
TV 2012 Toyota Tacoma 6 cyl
Misha the Lab
Loving life and living it!
dsmiths
Posted: 05 May 2013 at 7:14pm |
That probably is normal. Mine will make about 2 turns and starts to get snug. make sure you clean threads well with wire brush. wrap Teflon tape around threads on the anode rod about 2 or 3 times (put the tape on clock wise). hand start the anode in. after about 2 turns it will began to tighten. tighten about 1/3 to 1/2 more turn with wrench. Do Not over tighten. turn on water and check for leaks. you'll be ok. just don't over tighten.
Dane and Donna Smith
2011 RP-172
lift kit
Posted: 05 May 2013 at 7:30pm |
As above..
Clean threads, new teflon, screw in until tight. Check for leaks. Camp.
Posted: 05 May 2013 at 8:27pm |
The plug is pipe thread. Pipe thread is tapered so it will run tight and not leak. As said, add tefflon tape, make tight, check for leaks, camp.
2011 R-Pod 177
2010 Ford F-150
Outbound
Posted: 06 May 2013 at 6:42pm |
Use a brass brush to clean the threads - I bought a toothbrush-shaped one at the dollar store that works great.
Also, my plug doesn't screw flush into the heater; it sits proud about 3/8". That said, YMMV
Posted: 06 May 2013 at 9:06pm |
Pipe threads are meant to get tight. TT
gappman
Posted: 11 May 2013 at 1:01am |
I pulled mine out and put a drain petcock in its place.
Gary Piazza
www.garypiazza.com
Posted: 11 May 2013 at 7:07am |
In two seasons mine is half gone. I would rather have the sacrificial rod melting instead of the heater.
2011 R-Pod 177
2010 Ford F-150
hogone
Posted: 11 May 2013 at 7:39am |
mine is half gone as well...........do you know if it basically dissolves, or are there actually chunks of it inside the heater?
Posted: 11 May 2013 at 11:31am |
Originally posted by gappman
I pulled mine out and put a drain petcock in its place. |
Not a good idea! Google anode rod a little bit and find out why water heater manufacturers put these annoying little consumables in their water heaters in the first place. They aren't necessary in the short run but they have a major impact on the life of your water heater. Considering that most, if not all, of the opportunity for water heater failure is while you're on the road away from home, the inconvenience of fixing or replacing a water heater probably outweighs the expense, which will be way more than the cost of an anode rod. TT
