  New Posts New Posts RSS Feed: Water in battery box
Topic ClosedWater in battery box
bc matell View Drop Down
Direct Link To This Post Topic: Water in battery box
    Posted: 26 Nov 2012 at 5:34pm
Hi all,
I just took the battery out of the battery box on the trailer and it was sitting in about an inch of water. The pod is parked out side and there has been a lot of rain here for the past 3 days.
?? Has this hurt the battery and I thought the box was water tight untill I saw two small vents on top of the box.
Thanks for any help,Oh I winterized it by myself no problems.
TV 2012 Toyota Tacoma 6 cyl
Misha the Lab
Loving life and living it!
coopercdrkey View Drop Down
Direct Link To This Post Posted: 26 Nov 2012 at 6:19pm
Probably no harm to a new battery.  The cases keep in acid, they should keep out rain water!
I might do something like get a big shower cap that can be stretched over the battery box and still allow for venting.
Then you can leave the box on the A-frame for an occasional peek inside during winter storage.
You do disconnect the battery when not needed, right?!?!  And a periodic sip of juice from the charger??
Bob and Joyce
RP 177 "Key Pod"
TerryM View Drop Down
Direct Link To This Post Posted: 26 Nov 2012 at 7:30pm
Just drill a couple of holes in the bottom like I did.  Mine filled up 1/2 way with water.
Terry
Racer|X| View Drop Down
Direct Link To This Post Posted: 26 Nov 2012 at 7:53pm
To my surprise I found mine was 2/3 full when I took out for winter.
Direct Link To This Post Posted: 26 Nov 2012 at 9:08pm
We had the same problem...drilled a couple hole and problem was solved. We always diconnected the battery and also throw it on a trickle charger during the winter.
Direct Link To This Post Posted: 26 Nov 2012 at 10:33pm
This is one of the reason why I like to have LP tanks and batteries out of the weather, everything stays clean and dry.
Paige View Drop Down
Direct Link To This Post Posted: 27 Nov 2012 at 10:00am
Wow, that is a fantastic looking container! Did you make that? Can you tell us more about it?
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Direct Link To This Post Posted: 28 Nov 2012 at 8:49pm
what is the outside material that u used? wonderful job, u could sell them! would u make one for me?
Misha the Lab
