Chuck
Topic: I went left it went right Posted: 23 Jul 2011 at 9:22pm |
Well we're home safely and the Z Pod's safe and snug. If nothing else I think I've learned to check for a good hook up. Life's lessons continue.
Z-pod
Chuck Janet & Bogie the dog
'12 RP 177
1972 Shasta 1400
2005 Ford F-150 5.3L V8
Iteach5th
Posted: 23 Jul 2011 at 8:29pm |
I always check that tab. Stick my finger in there after it's all locked down to make sure I feel it in the right spot.
2011 RP-177
2009 Jeep Cherokee
1982 Coleman Redwood pup
secretbard
Posted: 23 Jul 2011 at 7:07pm |
Holy sh*t batman. That is terrifying to say the least. I'm glad to hear everything worked out, and safely. Every time I've lowered the hitch onto the ball, I feel and see it seat, but I've often wondered. I do make sure the latch is pulled completely forward before pushing it back over the ball to lock it, but I've never cranked the Pod back up to check it.
2010 Rpod 172 :)
2004 Chevy Trailblazer
cane2
Posted: 23 Jul 2011 at 6:48pm |
Been there done that, I lost mine on a railroad track at about 40 mph. Nothing happened at all, hooked backed up and put pin back in brake and changed shorts and drove off. NOW i crank the pod back up to make sure every thing is where it should be.
harleyguy1
Posted: 23 Jul 2011 at 6:28pm |
I always push the latching lever on the trailer hitch forward as I lower it onto the ball, this will assure you it is open all of the way.
Marshal
2011 R-177
Longview, Tx
Hodge-PODge
Posted: 23 Jul 2011 at 2:18pm |
Chuck's post kind of scares me. I didn't realize the locking tab COULD ride on the top of the ball!
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
Bigbit
Posted: 23 Jul 2011 at 2:07pm |
Wow, I'm getting old. I missed the second part of Goose's post and recommended the same crank-up procedure.
At least our advice is consistent!
Goose
Posted: 23 Jul 2011 at 2:06pm |
I can't answer that one as this is the first trailer that I have pulled with electric brakes, they are still new to me too.
Bigbit
Posted: 23 Jul 2011 at 2:04pm |
The best way to tell that you put things back correctly is to hook up the trailer to your TV, and drive down a quiet side street. If you toggle the manual engagement switch on the electric brake controller, you should feel the trailer brakes engage when you engage the brake switch and release when you let go. If the trailer brakes are on all the time, your emergency switch is still engaged.
As for the ball hitch, I do the same thing as Goose. If you want to double check things, after you think you've connected the ball hitch, crank the trailer hitch jack to lift the trailer a good bit. If the jack lifts both the trailer and the butt end of your TV, you're probably hitched correctly. Visually check everything as Goose recommends, too.
Chuck
Posted: 23 Jul 2011 at 11:37am |
On a related subject. After I rehooked, I was concerned that the emergency brake may have been engaged and in checking it, I pulled the plastic piece out of the connection and just pushed it back in until it seated. Was this correct?
Z-pod
'12 RP 177
1972 Shasta 1400
