FISHTAIL
Topic: TV Mount Posted: 26 Jul 2011 at 10:35pm |
Originally posted by Tri-Pod
We have a 176 and I just drilled two holes, one on each side of the plastic stand and screwed two flat headed SS screws through the holes and into the wood shelf. This way I don't worry about the TV shifting during transport. It seems to me the Tv is large enough to be seen from any place in the camper. I also attached a web belt to the back wall which I strap around the Tv when we are moving to take the strain off the plastic stand. I have used holders like the one pictured and they work well if you need that kind of adjustment. We only watch DVD in the evening when we are in bed, so most of the time the Tv is off. Hope you find something that works for you.
The only think I plan to change is to move the speakers to the end of the camper. We are constantly having to change the volume when the air conditioner goes on and off. Now that is a real pain in the dark. Clark. |
Cool, yeah I didn't want to use the stand for whatever reason. I just bought a wall mount, braced the back of the entertainment center, and wall mounted the TV. It is extremely sturdy, so I don't need to worry about straps or anything. I did mount it low so it would have some extra ventilation, but I may end up moving it up so that it's centered.
Tri-Pod
Posted: 26 Jul 2011 at 9:33pm |
2013 SP 240 w outside kitchen
5.7L V8
Me, My Honey, and Max our GSP
kymooses
Posted: 14 Jul 2011 at 12:14pm |
Originally posted by tpierce220
I'm thinking of Velcroing the remotes by the television. The one is so small and thin that it makes it very easy to misplace even in ¡Podtástic! |
Wanted to recommend to you all something I was clued into buying by one of the Forest River Engineers recently. There is an IR Repeater cable that you can buy that plugs into the back of your Jensen stereo dvd/combo inside the pod. Once you run the wire you can use the stereo dvd controls from the garage of your Pod. We run dvd's at night when we're in the dome playing games or just relaxing and I hated never being able to control the volume or pause the dvd's or anything.
tpierce220
Posted: 14 Jul 2011 at 11:02am |
FISHTAIL
Posted: 13 Jul 2011 at 2:01pm |
@Fishtail, I would call Forest River and ask them how much the mount will cost. It does stay flat though I keep the television in the garage during travels because they put a strap back there to secure the television. While I'm sure that the television is not going to pop off the mount as it does snap in place, I really don't want to tempt fate. LOL |
elementFont |
font-family | | font-size | | font-style | | font-variant | | font-weight | | letter-spacing | | line-height | | text-decoration | | text-align | | text-indent | | text-transform | | white-space | | word-spacing | | color | | Background |
bg-attachment | | bg-color | | bg-image | | bg-position | | bg-repeat | | Box |
width | | height | | border-top | | border-right | | border-bottom | | border-left | | margin | | padding | | max-height | | min-height | | max-width | | min-width | | outline-color | | outline-style | | outline-width | | Positioning |
position | | top | | bottom | | right | | left | | float | | display | | clear | | z-index | | List |
list-style-image | | list-style-type | | list-style-position | | Table |
vertical-align | | border-collapse | | border-spacing | | caption-side | | empty-cells | | table-layout | | Effects |
text-shadow | | -webkit-box-shadow | | border-radius | | Other |
overflow | | cursor | | visibility | |
Yeah, I'll likely do that a little later. I went ahead and used the mount I'd already ordered for now. Basically, I just cut a 1x4 into 2 12 3/4" lengths (the distance between "studs" in the back of the entertainment center), pre-drilled everything, did some measuring then installed them. Then I just mounted the TV mount to those two boards. I stained them first, but that was probably pointless because they are impossible to see.
I also mounted the TV low..first to hide the wires behind it without me having to tie everything up and out of sight (not much working room back there for that), and second to give it some extra room to vent. Then I put velcro on the back of the remotes and attached them to the inside wall of the entertainment center above the plugs. Works great. Everything is secure and out of sight.
Although, it's worth noting that it does look a bit funny to have the TV not centered. I might move it up later.
elementFont |
elementFont |
2Peas-n-Rpod
Posted: 04 Jul 2011 at 12:30pm |
@kymooses--We leave the tv in the garage unless we're camping when it will come inside the trailer. I've not been in a position where there's been a problem using the garage. It's been a blessing to use it to prep and to do dishes.
... I keep the television in the garage during travels because they put a strap back there to secure the television...
We also have the 182G, and on our recent trip to Montana, we used it in both places (garage & inside). Absolutely love being able to watch a DVD while preparing the food. I decided it would be more secure traveling with it inside the 'pod instead of in the garage, so I removed the straps from the back and screwed them into the wood frame surrounding the inside TV mount area. Just to keep it very solid, I cut down a block of styrofoam to put underneath it to keep the TV from jiggling around. I placed that between the bottom of the TV and the lower part of the frame. Works like a charm, and it keeps the TV very secure while traveling over the bumps of all that summer road construction!
2011 R-Pod 182G Hood River Edition
"Ribbitt" Pod (now sold)
2000 Ford F150 5.4L V8 TV
kymooses
Posted: 29 Jun 2011 at 10:58am |
I haven't had a problem using the garage, just not as much room to set up chairs and watch the tv back there I've found. Also I took the strap from the garage and moved it into the inside. This way our tv stays inside strapped up against the wall unless we want to watch it outside at night or something. Love the garage for the cooking and dishes. It's the perfect area for all of that!
tpierce220
Posted: 29 Jun 2011 at 10:54am |
FISHTAIL
Posted: 29 Jun 2011 at 10:41am |
oh man, I like that. That's much nicer than the 20 dollar mount I purchased. Plus, with that I could swivel the TV around and watch it through the door. I assume it locks flat against the wall for travel. Any idea what the brand name/model is of that thing? I'd love to order one of those. elementFont |
kymooses
Posted: 29 Jun 2011 at 8:24am |
@tpierce220 ~ Do you find yourselves using the mount in the garage much yet? In our 181g I found that our garage is almost always up against trees at a campground and never much room to even think of using the tv back there. This past week I moved the TV mount in the garage and added it into the Rdome seating area just beneach the window by the door. The wife and I are enjoying it much more there now.
