  New Posts New Posts RSS Feed: Water Heater not Heating Properly
ChrisG View Drop Down
Post Options Post Options   Quote ChrisG Quote  Post ReplyReply Direct Link To This Post Topic: Water Heater not Heating Properly
    Posted: 29 Jul 2025 at 3:41pm
Hey Everyone,
I have a (new to me) 2017 Hood River Edition. The trailer has sat unused for two seasons.  The Water Heater is firing up (flame is visible) and water is moving through it, but it's not making much, if any, hot water.  I let it warm up for a couple of hours, ran the water through the sink for a while, and yet the water temperature never got hot, only intermittently warm and cold.  I tried to take a shower but it wasn't an enjoyable experience.  Any thoughts or recommendations?
Thanks in advance for any insights or suggestions.  Sincerely, Chris
poohbill View Drop Down
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 4:58pm
It sounds like the cold and hot feeds are being mixed somewhere along the line. Does this happen on both City supply and pumped from tank?
2016 179 Gastropod
2017 Ridgeline
Post Options Post Options   Quote ChrisG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 5:45pm
Good question.  I haven't tried it with a city supply.  I'll experiment with that first.  Thanks for the suggestion.  Sincerely, Chris
Post Options Post Options   Quote poohbill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 5:49pm
Check also that the pressure relief stopcock is closed. Let it heat a minute before opening a faucet. Let us know if it spits air after running a minute.
2016 179 Gastropod
2017 Ridgeline
Post Options Post Options   Quote ChrisG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 5:56pm
I will do that.  Thanks again.  Chris
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 7:14pm
It is likely that the valves (2 or 3) are in winter mode, allowing the situation you are experiencing.  If it is a 3 valve system, make certain the lines running to and from the HW tank are open (valve handle will run parallel with the water line.  The third valve is between the top and bottom valve - this must be in the closed position (handle will be perpendicular to the water line) and will be opposite of the top and bottom valves.
Post Options Post Options   Quote ChrisG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2025 at 7:22pm
That's awesome advice.  I'll pull the bed out and take a look tomorrow.  Thanks for such thoughtful guidance.  Sincerely, Chris
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 9:56am
+1 to Jato's advice. If the valves are in the wrong positions, that would explain the intermittent warm and cold water. Given the age of the trailer, I expect that it has the three valve system. The top and bottom valves are likely open but it sounds to me like the bypass valve (the one between the top and bottom) was left open. Close that, and you should be able to enjoy a hot shower.
Post Options Post Options   Quote ChrisG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 10:13am
Thank you everyone for your great advice.  Both pieces of advice were correct!  The pressure relief stopcock was indeed open and the valve was open between the hot and cold water lines at the water heater.  I closed both and now the hot water is working.  Thank you so much!  Chris
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 11:23am
You are quite welcome ChrisG!  I have been on this forum for quite a long time and I have benefited many times on having access to this 24/7 owners manual.
