batteries won't stay charged |
ronnieb ![]() Newbie ![]() Joined: 24 Oct 2020 Online Status: Offline Posts: 9 |
![]() ![]() ![]() ![]() Posted: Yesterday at 10:00am |
My batteries won't stay charged after reaching 12 volts with a solar panel nor will they charge after driving. What to do?
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2704 |
What are you expecting? Batteries do self-discharge, even with no load. So expect to have to charge them at least once a month without a load.
Separate from that, there can be parasitic loads that will discharge a battery much more quickly. In extreme cases, maybe only a day or two. You need to use a DC-capable ammeter to see what parasitic load you have. The parasitic load on our RP179 is about 1/4 amp, or 250 milliamps.
Hi Glue Guy, I do charge the batteries every month, but on this last road trip, the batteries were at 7.6 volts after driving 10 hours..not enough to open the slide. I hade to start my truck to operate it.
How old is the battery? Are all cells filled with water? Are all connections clean and tight? TT
FJ Cruiser |
Hey TT, The batteries are maybe 3 or 4 years old, I'm diligent about recharging them every month but on this last road trip I had to add distilled water.Still not able to keep a charge. I think my next move is to remove them and have them tested.Any other thoughts?
It's a bit of effort, but probably worth disconnecting every cable, from the ground on the frame, the batteries, and from the batteries to the converter, wire brush everything, and put it all back together. Then, if necessary, have the batteries tested. Could be something else, but that's probably what I'd do. TT
FJ Cruiser |
