  New Posts New Posts RSS Feed: furrion description
furrion description
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: furrion description
    Posted: 12 Apr 2025 at 5:26pm
One additional thing is to remember to turn on the antenna booster (the button on the panel for the coaxial connection that goes to the TV). Be sure to turn it off as it will over time drain your battery if you are not using the trailer and it is in storage. Also, if you intend to use satellite TV and connect to the outside connection, turn the antenna booster off.
JohnF View Drop Down
Post Options Post Options   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 5:26pm
that is what I needed thanks
John F
Post Options Post Options   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 5:20pm
excellent thanks for the info
John F
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 4:51pm
The t.v. if i remember. is fairly simple. Ive changed models. I think you can watch just over the air t.v. with the campers antennea. On the remote, press menu, then choose air (i think). Then it will give you a choice to scan, it takes a minute, and it will look for any channels you can get. If you say hook up a fire stick to hdmi 1 (or hdmi 2 etc..) you go to menu, choose hdmi 1 (or 2 or 3) and it will bring up a list of apps you can use. You of course would need an internet hotspot of some sort. Good luck
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 3:23pm
Not being sure of what Furrion unit is in your RPod, I would suggest getting the model information and doing a search for a manual.
This would be a good place to look:  https://furrion.com/pages/downloads-audio-visual
Post Options Post Options   Quote JohnF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 1:18pm
Just got a 2020 R-pod 196 no documentation on TV connections or Furrion usageConfused
any info would be appreciated
JohnF
John F
