2018 2 Battery Setup |
Author | ||
KarlHavoc ![]() Newbie ![]() Joined: 16 Mar 2025 Online Status: Offline Posts: 4 |
![]() ![]() ![]() ![]() Posted: 17 Mar 2025 at 3:00pm |
Hello, I'm needing to replace the battery in my 2018 rpod and am upgrading to 2 batteries. My original idea was to connect these batteries with a switch like this switch https://g.co/kgs/bAMJwfR. I used this type of setup on one of my boats and it worked out great. I currently use a small solar panel that I plug in to the side of the rpod and move around manually. The solar panel does have a controller built in so it doesn't over charge the battery.
I guess my question is, is this a good idea for a 2 battery setup? will having my switch set to both batteries still charge both batteries equally with solar panel and the aux power from my pickup? Thanks in advance
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3359 |
Since this setup worked well on your boat, it should work equally well on your rpod. As long as your vehicle and 7 pin Bargman plug is setup for charging, you will be good to go. I have batteries of different ages so I use one at a time, changing out when the voltage drops to 12.2. I carry two 12v, they are: 14 year old Interstate deep cycle and a 4.5 year old Trojan T-1275. Without using solar or generator I can go off-grid for 6 days when night temps are in the 40's with day temps in the 50's or better. Having both batteries of the same age is critically important and you will have that setup - good to go. Edited by jato - 17 Mar 2025 at 5:20pm |
I spoke to a local RV dealer today and they made it sound like it was going to be an issue with switching to both batteries.
I don't understand their reason why. If you are using a pair of 6v and wire together in 'series' to get 12v you are set. If you wire a pair of 12v together in 'parallel' you still have 12 volts. I would entertain their thoughts as to why either of the above scenarios would not work for you.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 404 |
jato, if that battery gets any older it's going to be eligible for Social Security.
Gpokluda
I don't understand using a switch. If you put two batteries in parallel, they should draw down equally (within reason), and charge equally. At least thats the way it works in my camper. My batteries stay within about 3 % of each other
Me neither. This is big on the Escape forum as well. Folks will have two battery banks with a switch between them to switch from one bank to the other. Seems to be a thing in the boating world, but I'm not a boater so I guess I am missing it.
Gpokluda
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6445 |
It makes sense for a boat. If you accidentally run down your battery while out fishing, you can switch and still start your engine to get home.
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2714 |
Might be why they put two separate ignitions in airplane engines too.
