Hot water tank - Event Date: 13 Feb 2025 |
Jsappington0717 ![]() Newbie ![]() ![]() Joined: 18 Oct 2024 Location: St. Charles Mo Online Status: Offline Posts: 8 |
![]() ![]() ![]() ![]() Posted: 13 Feb 2025 at 11:17am |
Where is the hot water tank on a 2021 R-Pod 193. Bought camper used and need to dewinterize it.
J. Sap
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6423 |
Easy way to spot where it is roughly is to see where the water heater panel is on the outside. Then look inside at that area for an access panel or door or (if under the bed) under a panel. I don't have that model, so I can't say for sure, but that is where I would start.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
Hopefully the previous owner did not fill it with 6 gallons of antifreeze! The bypass valves and pump should be in the same general area.
Gpokluda
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2708 |
Most Rpods have the water heater access and the vents for the furnace co-located on the side of the trailer.
The large, black panel is the cover for the water heater. The two round vents are the furnace. ![]() |
Pete Brayton ![]() Senior Member ![]() ![]() Joined: 29 Jul 2015 Location: Parker, CO Online Status: Offline Posts: 128 |
It looks like your hot water heater is located between the rear storage area and the slide out the driver's side.
https://www.youtube.com/watch?v=-diIkDBMra0&ab_channel=BennieAust
2021 Rpod 196
2013 Ford 150 V8 |
