  New Posts New Posts RSS Feed: What size generator
What size generator
Gbr1955 View Drop Down
Post Options Post Options   Quote Gbr1955 Quote  Post ReplyReply Direct Link To This Post Topic: What size generator
    Posted: 30 Jan 2025 at 9:40am
I just bought a 2011 rp177. Has a ac 13500. What size generator do I need?
George Roth
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 10:12am
It depends on what your power usage will be aside from your AC. If you are only going to use AC and it has a soft start mechanism, you can get by with something as small as a 2000 watt inverter generator. If you are going to be running the AC and microwave and other appliances, you will need a 3500-4000 watt unit. Figure out what your power usage is going to be and size accordingly.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 5:20pm
+1
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 8:33pm
If you are careful to not try to run too much at once, a 3,000 watt generator should be adequate. If weight is an issue, two 2,000 watt generators run in parallel will be easier to lift. If you plan on running a dual-fuel generator on propane (which is what I do), remember that it won't generate quite as much power when running on propane. However, it avoids having to carry gasoline.
john in idaho View Drop Down
Post Options Post Options   Quote john in idaho Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 11:08am
It might also depend on the charge status of your batteries when you turn on the AC.  If your batteries are down when you startup the generator the AC may not start because of the load from the battery charger.
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 8:37am
I have a 179 from 2016.
My Microwave would bog down a 2000 generator and the AC would kill it.
This cured the problem.
https://www.amazon.com/dp/B0C1Q4K2G7?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 9:09am
I had installed one of these in our (former) RP-179 to allow use with a Generac 2k generator. It is expensive, but worth getting and installing. You will notice a significant difference in AC startup as it doesn't have that sudden 0-100% but ramps up the speed of the compressor so that you barely hear it start. You just notice the cool and that it doesn't bog down the 2k generator.
The reason it works is that it cuts the initial current surge that the AC draws when starting up. It won't make up the deficit of a cheap generator, but a quality generator will work.
I have not installed one in our current Grey Wolf because we had gotten a larger generator because I wanted one that could run on propane. If I still were using the 2k generator, I would have gotten and installed one in the GW also.
Caveats:  A 2k generator will still bog down if you try to run too much at once. You can run the AC or the convection microwave, but not at the same time. If the battery is low and the converter is trying to bulk-charge it, that also may be too much draw to run the AC at the same time but if the battery is full enough to use float, then it will work.
Edited by StephenH - 24 Mar 2025 at 9:15am
