Brakes |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6423 |
![]() ![]() ![]() ![]() Posted: 22 Nov 2024 at 7:02pm |
Use the manual control for your brake controller to activate the brakes in an empty parking lot. You will be able to tell if they are working and how well they are working.
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
I would just go to an empty parking lot dial up the gain and see if the wheels lock up. You'll find out pretty quick if the trailer brakes are working.
Gpokluda
tkchamb ![]() Newbie ![]() ![]() Joined: 30 Mar 2022 Location: Beaufort, NC Online Status: Offline Posts: 3 |
Will try , thx
Good idea, I have a laser temp gun. Thx
seafans ![]() Senior Member ![]() Joined: 24 Nov 2017 Online Status: Offline Posts: 163 |
Another way to check the brakes is to apply them gently for a few seconds, stop and check the temperature of the drum with your hand or lazer light temp gun. That way you can check to see if they need adjusting. One side will be hotter than the other.
We usually go to a LOW traffic dirt/gravel road and drive about 20-25mph. We use the brake controller to activate the brakes and the tires should lock up and skid hope this helps Travel often and safe Vann
How to check if my ro 176 brakes are woy?
