  New Posts New Posts RSS Feed: Brakes
Brakes
tkchamb View Drop Down
Post Options Post Options   Quote tkchamb Quote  Post ReplyReply Direct Link To This Post Topic: Brakes
    Posted: 14 Nov 2024 at 5:51am
How to check if my ro 176 brakes are woy?
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 9:43am
We usually go to a LOW traffic dirt/gravel  road and drive about 20-25mph.  We use the brake controller to activate the brakes and the tires should lock up and skid
hope this helps
Travel often and safe
Vann
Vann & Laura 2015 RPod 179
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 3:41pm
Another way to check the brakes is to apply them gently for a few seconds, stop and check the temperature of the drum with your hand or lazer light temp gun.  That way you can check to see if they need adjusting.  One side will be hotter than the other.
Post Options Post Options   Quote tkchamb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 4:00pm
Good idea, I have a laser temp gun. Thx
Post Options Post Options   Quote tkchamb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 4:03pm
Will try , thx
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 7:09pm
I would just go to an empty parking lot dial up the gain and see if the wheels lock up. You'll find out pretty quick if the trailer brakes are working.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 7:02pm
Use the manual control for your brake controller to activate the brakes in an empty parking lot. You will be able to tell if they are working and how well they are working.
