  New Posts New Posts RSS Feed: Using camper off-grid in winter
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Topic: Using camper off-grid in winter
    Posted: 04 Jan 2025 at 11:28am
Originally posted by David and Danette
  When we camped off grid during cold temps we used a portable Mr Buddy propane furnace. We used a solar pannel and a generator to help keep battery charged but found the camper furnace drained the battery to fast, we only had one battery.
We ran into the same issue. We camp all year and winter camping in an Rpod takes a significant amount of effort and attention to detail. We added a second battery and carried an extra LP tank, which we also used for our CampChef stove, but in the end, we decided to upgrade to a camper that was more suited for four seasons.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote David and Danette Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 10:01am
2014 Ram 1500 Quad cab
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 12:17am
We have spent traveled and camped in the trailer at temperatures in the low single-digits. No water in the tank. Use RV antifreeze to flush if needed, but try to avoid using the toilet in the trailer. You will use a LOT of propane trying to keep the trailer at usual room temperatures. We kept the thermostat lower and dressed warmly. We also tried a Mr. Buddy. The small one was adequate, but top-heavy. I was always worried that it would tip over without me being there to catch it. I ended up returning the little one and got the Buddy which had much more output than we needed, even on low, but it was much more stable.
Good, warm sleeping bags are great to have. Adding some insulation under your mattress helps also. Possibly a layer of Reflectix would work. I had not tried that. I did insulate the platform underneath by using the foam sheets in the frame spaces that support the bed platform. That was also quite helpful.
KirkH View Drop Down
Post Options Post Options   Quote KirkH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 11:24pm
Late to the party here but I have taken my Rpod 192 to ski resorts at 10,000’ altitude several times. Once in No ember I actually took fresh water and showered. In midwinter, we don’t use the plumbing. We might urinate in the toilet at night but try not to. We use a Mr Heater Buddy propane heater. We keep the furnace thermostat at 50 degrees at night. We carry a generator and solar panels to recharge batteries. We use electric space heaters while the generator is running.
Condensation is an issue. We keep the vent fan running and use a sponge and bucket to wipe up condensation. Other than that we have no problems. We have camped at 10,500’ in a blizzard with 40 mph winds and 3’ of snow.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 7:22pm
The coldest weather we have camped in over the past 14 years with our 177 is 22 degrees F.  The propane furnace ran a lot and we kept the windows on both side of the bed open about 1/4" for ventilation.  The times we kept everything closed, even at 35-40 degrees was not good, a lot of condensation on the walls, actually too much!  There is a way to avoid condensation but I don't recommend it - stop breathingLOL - not a viable option for sure!  We have camped in cold weather but used compressed air to clear the lines and basically dry camp.  As has been stated above, the r-pod is not intended to be used in cold winter climates, unless you are going to dry camp, and from your post, that is not your intent.
TimeOutside View Drop Down
Post Options Post Options   Quote TimeOutside Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 10:33pm
Responses...
Thanks Tars. I'll dig into this a bit more.
PS. I never imagined campers on Barsoom. πŸ˜€
Some ideas are so preposterous that only an intellectual can believe them. - Malcolm Muggeridge
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 7:55pm
Originally posted by TimeOutside
Thank you everyone for your input.  It's not what I wanted to hear, but it is what it is.  I simply had no idea that campers would be made that could not be used year round.  It still baffles me that is how the industry works. But since the majority of the outings I purchased the camper for will be in seasons where a freeze is possible, I do want to explore options that will let me utilize the camper as intended as much as possible.  I hate to think I wasted my money.  (My wife will be really pissed.)  So, let me ask some additional questions and get your input, since I still don't know what I don't know.
Assumptions:
  • I'll be camping in my home area of southern Missouri &/or south.
  • I'll be able to view the forecast and have time to fully winterize if there is a long period of freezing temperature coming.
  • In my home area, the typical freeze is no lower than 15 degrees F.  Sometimes it is in the mid-20s.  Usually it is in the upper 20s. Rarely does it remain below freezing during the day.
  • At 15 degrees F, with 15 gallons remaining in my fresh water tank and a starting water temperature of 40 degrees F, it will take almost 34 hours for the water to freeze.
  • At 15 degrees F, with 2 gallons in a grey or black water tank and a starting water temperature of 40 degrees F, it will take almost 4.5 hours for the water to freeze.
  • See the Water Freeze Time Calculator for other values.
You can probably get by into the mid 20s for a few hours, but it's risky.  The tanks don't have to freeze solid for you to have a problem.
So, for the tanks:
  • It seems to me that if I start out with a full 30 gallons in my fresh water tank and don't let it dip below 15 gallons that I have a very low risk of running into trouble, as long as I keep an eye on the forecast.
  • It seems to me that if I dump some food grade antifreeze in my black and grey tanks (and the lines leading to them), I should also have a very low risk of them freezing.
  • Does this seem correct to all of you?
Yes.
  • Do I have access to the bottoms of the tanks?  (I won't have the opportunity to look until later this week.)  If so, I can stick heating pads on the undersides.  I have a hybrid truck equipped with a 2k watt pure sine wave inverter.  I will always have access to AC power, although I don't want to run it continuously.
Now about the lines:
  • The lines are more problematic.
  • Do I have access to the length of all the water lines?  (I won't have the chance to look until later this week.)  If so, I can attach heat tape to them and wrap them with insulating tape.  The current draw of such tape is well within my ability to manage even when boondocking.
  • If I don't have access to the length of the water lines, for example the line to the shower being buried, then I have a problem.  I could leave the water dripping, but without a way to get the water back into my fresh water tank I'll drain the tank too quickly.  Also, I'm not sure it would be good on the pump.
How much do you know about electricity?  If you are powering heating pads and tape with your inverter hooked up to the Pod battery, you won't make it through the night. Running your truck all night might work.  A generator would probably be better, but a lot of campgrounds don't allow generators after certain rather early hours.
  • It's not a big trailer.  It's about 52' around the outside.  I have the option of skirting it.  That would help a bit.
Yeah, that will help a bit.
About condensation:
  • As a long time winter tent camper, I'm familiar with this problem.  But I just don't know about campers.  How well insulated are the walls?  If I'm running a vent and have heat, is condensation really an issue at 20 degrees?
That will probably work.  You can adjust the vent depending on your results from night to night.
Thanks in advance for you input on all this detail.
Andrew
Post Options Post Options   Quote TimeOutside Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 4:52am
Assumptions:
So, for the tanks:
About condensation:
Andrew
Edited by TimeOutside - 29 Oct 2024 at 9:05am
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 8:20am
+2 to what everyone else has said. There are things you can do such as have the bottom sprayed with insulating foam and have heating pad installed on the tanks (but require your to be plugged to shore power). But none of these will make the Rpod of 4 season rig.
Another thing about cold weather camping in an RV that you need to be aware of if condensation management. You will need to have air flow in the trailer even though it is cold outside, in order to avoid having condensation build up which can lead to mold in places you won't be able to reach.
All of that said, winter camping can be fun. We did it quite a bit in our Rpod and still do in our current camper, but we relied on facilities that had toilets and showers such as State Parks. Our current camper has a composting toilet which allows us to use the toilet in the camper in the winter.
There are a number of 4 season campers out there. The two I see the most are Arctic Fox and Bigfoot.
Gpokluda
2022 Escape 5.0TA
Kawasaki KLR650
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 10:35pm
I agree with GlueGuy.  You need to blow out the lines or fill them with RV antifreeze and not use the Pod plumbing if temps are going to be below freezing for any length of time
You won't be able to use the sink or shower.  You have to really watch the waste tanks too -- you could use the toilet and flush manually with RV antifreeze, but that could be risky.  Winter camping in an RPod can be a lot more comfortable than winter camping in a tent, but you almost have to have access to campground restrooms and showers.
