  New Posts New Posts RSS Feed: Slide not plumb
Slide not plumb
Rdenniso View Drop Down
Post Options Post Options   Quote Rdenniso Quote  Post ReplyReply Direct Link To This Post Topic: Slide not plumb
    Posted: 07 Jul 2024 at 9:48am
Slide on our 2022 RP202 has been out of plumb since we purchased the unit. When "In" it is tight against the camper at the top, but to bottom is out about 1". What can be done to correct thi issue?
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 10:47am
It sits on rollers, but they're pretty close together. What is it like when it's extended?
Post Options Post Options   Quote Rdenniso Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2024 at 1:51pm
Extended it is slightly out of plumb. Hard to say exactly how much, only had a 4ft level.
Is this a normal situation?
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 10:59am
Not for us, but I don't know about others.
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 7:10am
We have a 2019 / 179 and picked it up new in July of 2018 and just by eyeing the slide out it has never looked wonkey
Jay
179/2019
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 7:59am
My 180 slide was shifted forward enough the seal tore and I had to replace it.  Did not leak water but very out of plumb.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 7:34pm
Picked up our 177 in March 2011.  Although the top is tight to the side wall, the bottom sticks out maybe up to 3/8", I think due to the thickness of the seal.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 7:36pm
I would take a look from the inside and remove any panel that may hinder you from seeing the bottom of the slide.  Once the slide is out you may find something sticking up that is preventing the slide from closing all the way.
