  New Posts New Posts RSS Feed: Wheel Bearing Grease
Wheel Bearing Grease - Event Date: 20 Apr 2024
IdahoBoy View Drop Down
Post Options Post Options   Quote IdahoBoy Quote  Post ReplyReply Direct Link To This Post Calendar Event: Wheel Bearing Grease
    Posted: 20 Apr 2024 at 12:00pm
I need to grease my wheel bearings and in the past have used a Kendall blue grease which is no longer available. How important is it that I use the same or similar grease? Any recommendations for the best grease to use and do I need to pump out all the formerly used grease?
As you can tell I'm operating from a place of total ignorance on the subject so thanks in advance for the good advice I know I will get here.
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2024 at 11:38pm
The Valvoline synthetic grease is rated about the best.  Use good grease seals or the grease will leak out and contaminate the brakes.  Pack the bearings by hand.  Both my 180 and 192 when purchased new the brake shoes and brake magnets were contaminated with grease.
hogone View Drop Down
Post Options Post Options   Quote hogone Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 7:23am
I use the zerk fittings since day one; works great, no leakage.  Just go slow and spin the wheel as you fill.  pump until you see all new grease; the old will come out  Hope that makes sense.
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 10:44am
I don't know if I'd mix greases. They will certainly have slightly different viscosity and/or heat profiles. If you hand-pack, you will remove that uncertainty.
That said, we have used Lucas Red N Tacky from the get-go. We also just use the zerk fittings and avoid over-filling.
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 4:43pm
According to grease people, one should avoid mixing different types of grease or it can do bad things in the bearings and seals.  Here's a handy chart of compatibility prefaced by a caution to avoid mixing different types.  https://www.lelubricants.com/wp-content/uploads/120-Grease-Compatibility.pdf  We use the same Red N Tacky grease as Glue Guy and it has worked well  We follow the instructions of Lippert using the zerk fittings and spinning the wheels while applying the grease.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 7:42pm
Old School here, I like to visually inspect and hand pack.  50 years in the golf industry and have seen a lot of bad bearings due to a lot of bad maintenance practices; mixing grease is a big one to avoid.  I like to hand pack every other year, clean bearings and races first, visually inspect and then hand pack.  The Red N Tacky is an excellent grease.  Personally I use Schaeffer's 219 SynForce Green, waterproof and a high pressure grease as well.  On the years that aren't hand packed, I will do the same as lostagain and Glue Guy, about 3-4 pumps in the zerk while spinning the wheel.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 11:22pm
Thank you. This chart is quite helpful. I did not know there were so many different types of grease.
James07 View Drop Down
Post Options Post Options   Quote James07 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2024 at 2:05pm
If you are able to manually repack the bearings, that is preferred so that you can exam the bearings.  Only my first repack, one bearing had flat spots and had to be replaced.
